Needle Jet Position
  • jwinatlanta
  • jwinatlanta's Avatar Topic Author
Needle Jet Position
27 Apr 2026 19:30
#923399
I am in the process of putting a rack of Keihin CV34's back together when I realized that when I was taking them apart I didn't make a mental note of the direction the needle jet goes into the body of the carb..
Any help would truly be appreciated.
jwinatlanta
  • zed1015
  • zed1015's Avatar
Re: Needle Jet Position
27 Apr 2026 23:24
#923404
If the needle jet has a semi circular shroud that protrudes into the venturi it should be fitted with the opening facing the outlet of the carb ( towards the engine )..
  • jwinatlanta
28 Apr 2026 05:46
#923413
The needle jets on this set are flat on both ends. When looking through one end it appears to be smooth. Looking through the other end there appears to be a step in the bore.
My guess is to put the smooth bore end exposed in the venturi. But that is a guess.
  • jwinatlanta
29 Apr 2026 20:05
#923486
Does anyone have an offer to the original question?
