Jet needles
- Maxbou92
Jet needles
23 Apr 2026 03:46
Good day everyone, In wondering what kind of Jet needles are you using in your VM carburetor?! 5dl31, 5cn13, 5dp7 ?! There’s a lot of models and shapes.. I’m curious about that!
Kz750e 1980
- zed1015
Re: Jet needles
23 Apr 2026 05:31 - 23 Apr 2026 10:59
You should use whatever is stock with your carb.
The jet needle is not a stand alone item.
It is designed to work with the corresponding needle jet and slide cutaway etc to deliver the optimum fuel curve for a specific mix of components that make up the carb specifications for your particular model.
This is why the same carbs from other years that are made up of different needles, jets and slide cutaway configurations will still work correctly when substituted with your originals.
Last edit: 23 Apr 2026 10:59 by zed1015.
The following user(s) said Thank You: Injected
- Maxbou92
Re: Jet needles
23 Apr 2026 05:55
Thank you Zed, I was thinking that I could try a different one richer at 1/8 throttle and keeping the same needle jet!!
Kz750e 1980
- Injected
Re: Jet needles
23 Apr 2026 07:59
Generally if you fit a richer jet needle (by the number) without changing to a corresponding recommended needle jet size it will be rich at every throttle setting. Raising or lowering the clip height is the only suggested way to change the tuning.
Mikuni VM carbs as fitted to stock engines at Kawasaki or Suzuki (mostly) had set tuning parameters for those specific setups (air box with stock dual exhaust) If you deviate from those parameters your always going to have to put up with gaps in the tuning at certain throttle settings. Even from the factory those stock bikes did not have "perfect" tuning, they had to make compromises for mass production.
1978 KZ650B2 modified project
- Maxbou92
Re: Jet needles
23 Apr 2026 09:29
All right!! That’s more complicated than just playing with Jet needle
thank youu
thank youu
Kz750e 1980
- Injected
Re: Jet needles
25 Apr 2026 08:39
Yes, those two parts are "matched" to the fuel delivery for the intended engine (KZ900/1000) If I remember correctly your using those VM's on a KZ750 so fueling would be different based on engine specs (bore/storke/CFM etc.)
You can get the jetting close but it will never be perfect just because of engine demand.
If you just swapped in richer needles you could be way off as the jetting "window" for optimal performance is only about 3-5% variance between a rich or lean condition.
There was a carb guru on here (wiredgeorge) but I am not sure if he is still actively posting. His web site is still up at www.wgcarbs.com
He would be the one to ask about swapping needles as he has done a ton of tuning on stock KZ round slide carbs. In his posts he always mentioning what needles were best for different combinations (use the search function)
- Maxbou92
