Kawasaki Z1 1974 1975 Bracketry Plus
- asphalt900
16 Apr 2026 05:55 - 16 Apr 2026 05:56
If anyone Needs presentable crap for their restoration, cleaned-up and plated bits for the 1974 and 1975 carb 2170's entertain yourself with this option. I've boxes and Tupperware containers full of this stuff. Won't mention the name of the Member who HELPED me Tremendously putting the icing on the cake for hardware refurbish on a couple of these but he doesn't want the notoriety. Anyhoot, this stuff will save you time and stave off greasy finger syndrome having to knock off the funk of yours. Have WAAAY more then pictured, even complete sets. Pictured in last photo is the Pulley Wheel difference. 1975's started using Aluminum, earlier Steel. PM me for details, Clay
Last edit: 16 Apr 2026 05:56 by asphalt900.
- sf4t7
Re: Kawasaki Z1 1974 1975 Bracketry Plus
16 Apr 2026 08:58
PM sent.
Scotty
1974 Z1A
Yoshimura 987, 10.25:1
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
- asphalt900
16 Apr 2026 10:27
Good Afternoon SF, PM replied to. Left You my phone number, faster and more efficient i believe. Plus we can text photos of what you'll be needing back and forth. If You have TWO springs then you have the 147 series and it gets complicated because of the variations of springs/pulleys and a mess of other details.
- sf4t7
18 Apr 2026 08:17
Hey Clay, thank you for the springs. Good talking to you on the phone. Just made a $40 donation to KZR for ya.
Scotty
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
The following user(s) said Thank You: Nessism, Wookie58
