KZ700 a bit stumped
- KeylAmi!
- Engineer with ADHD
KZ700 a bit stumped
11 Apr 2026 13:58
Ok… no sure where to go with this. It’s got symptoms that seem to span several categories.
compression: 125-130 across all 4 cylinders. This is slightly better than last check last year.
carbs have been synced
replaced intake boots (carb to intake)
replaced rubber bellows on choke plungers.
Pilots all clear
weird symptoms:
at idle:
remove cap from 1: little to no change
from 2: stutters hard
from 3: stutters hard
from 4: slight stutter
plug 1: golden marshmallow
plug 2: a little darker than one, oil on threads
plug 3: black, oil on threads
plug 4: same as 2, but no oil
no “smoke” observed in exhaust, regardless of throttle or load. Looking in cylinders, I find no indication of oil actually in the cylinders. Just on the threads.
idles pretty smooth, but something does sound off. Though it definitely does NOT sound like it’s missing 2 cylinders. Removing caps from 2 or 3 are the only ones that seem to significantly change the idle. 1 or 4 sound very slight, if any change at all. I would find it impossible that it’s detonation on 1 and 4. I am baffled because all the symptoms and observations conflict with each other.
final observation: under load, it’s gutless and obviously missing on at least 1 cylinder above about 4500 rpm. This make me lean towards an issue(s) with main jets/needles/slides.
(Stock airbox with freshly oiled filter)
what am I missing here?!
Pilots all clear
weird symptoms:
at idle:
Current project:
'84 KZ700
'84 KZ700
- StreetfighterKz
Re: KZ700 a bit stumped
11 Apr 2026 14:37
Were the carbs bench or vacuum sync’d?
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- KeylAmi!
11 Apr 2026 15:04
They were vacuum synced.
Current project:
'84 KZ700
'84 KZ700
- KeylAmi!
11 Apr 2026 17:43
Ok. Disregard this post. Unless troubleshooting same symptoms…
the container with air filter oil in it… did not have air filter oil in it.
I washed the filter out. Got new oil. Runs great now!
*intense facepalm noises*
Current project:
'84 KZ700
'84 KZ700
