Colourtune
  • kznutter
  • kznutter's Avatar Topic Author
Colourtune
03 Jan 2026 05:29
#920286
Question, what are peoples thoughts on colourtune. Are they any good or a waste of money. Saw one being used on a youtube video, and thought oh my god thats incredible 😜. Or am i being conned.
  • Warren3200gt
  • Warren3200gt's Avatar
Re: Colourtune
03 Jan 2026 05:43
#920287
Excellent bit of kit. The only way to get exactly the mixture you want without all the faff.
Remember that they only sort pilot circuits though as you don't want to rev above 3k rpm with the colour tune plug in so not up into needle jet/main jet range.
The following user(s) said Thank You: asphalt900, Wookie58
  • kevski
  • kevski's Avatar
Re: Colourtune
03 Jan 2026 06:53
#920290
Good bit of kit, I still use my dads one he bought in the 1960's and a second one I bought, I run two at a time to speed up the process.
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
Re: Colourtune
03 Jan 2026 09:07
#920295
Next best thing to an MOT gas analyser or AFR meter
The following user(s) said Thank You: asphalt900, bry195
  • Cra-z1
  • Cra-z1's Avatar
Re: Colourtune
03 Jan 2026 09:11
#920296
I have several for different threaded plugs. Very helpful if your trying to figure out a carb issue
  • kznutter
Re: Colourtune
03 Jan 2026 10:50
#920298
Looks like i'm buying a colourtune then, cheers chaps. Any perticular make are better than others.
  • Warren3200gt
Re: Colourtune
03 Jan 2026 11:08 - 03 Jan 2026 12:36
#920300
Gunson colourtune 14mm. It's also worth getting a long reach adaptor but not critical unless your first few threads are worn.
Last edit: 03 Jan 2026 12:36 by Warren3200gt.
  • Injected
  • Injected's Avatar
Re: Colourtune
03 Jan 2026 15:48
#920301
A Color Tune kit is the cheapest most accurate way to tune slow speed operation, anything else is just guess work.
The only other way to tune the pilot circuit on carbs is with a O2 sensor and AFR gauge (way more expensive setup)
1978 KZ650B2 modified project
  • asphalt900
  • asphalt900's Avatar
Re: Colourtune
04 Jan 2026 03:21
#920309
Not as if the point has not already been in favor of the Gunson but I too agree, super cool diagnostic tool to have in the box. I've been using these see-thru sparkplugs for decades and have all three 14/12 and 10mm adapter versions. 14mm is the one you'll be using if a Kawasaki. The 12mm i use for Hondas. The 10mm adapter is spotty in application because it is "just" an adapter and because the electrode is soo far removed from the combustion chamber, really tough to see the combustion color. Once you purchase and spend time with it in application you'll see it's benefits and limitations. Actually loaned out my 14mm out to one of the members here to do just that. Seems the prices have escalated since i purchased mine and availability has become spotty these days. Source/purchase and enjoy, You won't regret it.
  • kznutter
Re: Colourtune
04 Jan 2026 07:25
#920311
Once again, cheers chaps. I will look into the gunson ones. I have a kz1000, so a 14mm one will do the trick.
  • Cra-z1
  • Cra-z1's Avatar
Re: Colourtune
04 Jan 2026 09:24
#920319
It was the only way I was able to get an old BSA running properly a few years ago. I use it on the Z1 mainly to check the pilot circuit after a carb rebuild and make slight adjustments
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
Re: Colourtune
04 Jan 2026 17:59
#920325
Using the Gunson Colortune on my KZ1000.
Need to do it again in the Spring, now that a few more bugs have been sorted.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
