Hanging Idle 73 z1 900
  • P48ker
  • P48ker's Avatar Topic Author
16 Dec 2025 10:55
#919859
Hi all new member here
i have a 73 z1 all stock have an issue with hanging idle
it will stay at 2400 rpm then drop to normal idle
new intake rubbers
carbs ultrasonic cleaned vacuum balanced
could choke assembly be causing the problem original seal rubbers or any other suggestions  ?
thanks in advance
Mike
  • asphalt900
  • asphalt900's Avatar
Re: Hanging Idle 73 z1 900
16 Dec 2025 15:29
#919869
Mike there are two distinct different "types" of hanging idle. One being a leaking manifold other being an over-rich condition but burning it off slowly keeps idle too high. A vacuum leak doesn't generally go away, over-rich does. Double check your fuel level first. If choke plungers, i have a trick for that too. These ramp style carbs are finicky to start with and any glitch in the array of multiple springs/seats/levers can make things worse. Also if carbs have been "gone thru" make sure the jet holders haven't been over tightened. I warped, even slightly can grab the slide jet needle and keep it's slide from fully seating. Keep us informed.
  • Cra-z1
  • Cra-z1's Avatar
16 Dec 2025 16:34 - 16 Dec 2025 16:35
#919870
No mention of synchronization of the carbs? Did you sync them. Never mind I see you balanced them. What tool do you use.
Last edit: 16 Dec 2025 16:35 by Cra-z1.
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Moderator
17 Dec 2025 01:17
#919881
You could try slackening off the cables to eliminate a mechanical issue
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
17 Dec 2025 03:58
#919888
   Old grease in the advancer, under the points cam where it rotates on the advancer shaft can become very sticky with age, preventing the points cam from retarding when idle drops.  This can keep timing advanced artificially, which will keep idle high.  Disassemble the advancer, clean & lube under the cam and around the shaft with high-temp grease.  If you remove the advancer weights to clean & lube the pins, be careful not to stretch the springs.  Too, those tiny C-clips on the pins can get away easily, so take your time doing the R&R.
Good Ridin'
slmjim & Z1BEBE
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
The following user(s) said Thank You: MFP-Joe, Wookie58, P48ker
  • P48ker
17 Dec 2025 05:35
#919893
Hi
amazon vacuum gauges
  • P48ker
17 Dec 2025 05:42
#919894
Thanks for the help
i set float hight manually I will get the tube gauge
what is your trick with the choke ? I was going to buy new assemblies ?
  • P48ker
17 Dec 2025 05:44
#919896
Thanks
i did do that and no hanging slide
i did not check needle hight
has always been cold blooded and needed choke for some time
  • P48ker
17 Dec 2025 05:46
#919897
Thanks I did not consider that
  • Cra-z1
  • Cra-z1's Avatar
17 Dec 2025 07:10
#919903
Im assuming you calibrated those gages to one vacuum source.
  • P48ker
17 Dec 2025 07:40
#919905
Hi
yes all set on one carb
  • Injected
  • Injected's Avatar
17 Dec 2025 11:10
#919910
Yes if they are OEM from 1973.
1978 KZ650B2 modified project
1981 Z50R Honda tow bike
