Air filter
- kznutter
Air filter
24 Oct 2025 02:53
A question for all you carb experts.
I have a kz1000g that i have converted to carbs, however the air filter does need replacing as i think its the original filter, and is a little dirty. As with every part for this bike its as rare as rocking horse sh@t.
im thinking of dismantling the old filter and replacing the paper filter with foam, and then gluing it all back together. Would this work, and if so, what type of foam would be a good choice.
Re: Air filter
24 Oct 2025 03:21
If you look at "motorsport" suppliers they do sell foam specifically intended for this purpose
Re: Air filter
24 Oct 2025 04:38
UNI filter foam works well. I think the green stuff is good for motorcycle filters.
unifilter.com/online-catalog/accessories/
- kznutter
- Mr. E
Re: Air filter
24 Oct 2025 08:40
Just remember if you go to foam you will need to give it a good oiling! I had some good luck using generic air filter foams when rebuilding bread boxes - I always use UNI filter oil on all my bikes and have no complaints-
1977 kz1000 - the Rooster, 1981 KZ750 Chopper, 1975 KZ400 , 1984 GPZ750
- kznutter
Re: Air filter
26 Oct 2025 06:06
Mr E, yep, no problem, will do that. Looked at uni filter products, and i can get them in the UK.
- Kelly E
Re: Air filter
27 Oct 2025 19:29
I've used Uni 5/8" green sheet foam to make a new filter for my 84' Honda VF 700S with great results. I oiled it with K&N filter oil, it's what I had and works fine. The bulk sheet was $16 and was enough to make 4 filters.
1974 Honda CB 550 K0
1977 Kawasaki KZ 1000 LTD
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda Sabre 700
1984 Honda Interceptor 1000
1990 Moto Guzzi 1000
And more
1983 Honda CB 1100F
And more
