Keyster Mikuni Rebuild kit for Z1
  • danam
  • danam's Avatar Topic Author
01 Oct 2025 19:08 - 01 Oct 2025 19:29
#917795
My newly rebuilt Z1B is not running correctly no matter what I do. I used carb rebuild kits from Z1 Enterprises (China) and was told to use real Mikuni parts. I bought “Keyster” rebuild kits from Japan, they are far and away better and they come with a variety of sizes.  www.jp-stores.com/mc/we70630/?act=c2&c=404&icode=5603
Last edit: 01 Oct 2025 19:29 by danam.
  • Nessism
  • Nessism's Avatar
Re: Keyster Mikuni Rebuild kit for Z1
01 Oct 2025 19:28
#917796
Did you ungang the carbs and remove all the parts?  Soak the bodies in carb dip?  Shoot carb spray through all the passages, verifying all the internal passages are open?  I say this because replacing the jets won't clean inside the passages, and there could be gunk inside.
  • danam
01 Oct 2025 19:30
#917797
Yes I had the bodies professionally cleaned, we will see if these parts make a difference.
I tried uploading a video of the unboxing but had trouble. Here's a youtube video
  • hardrockminer
  • hardrockminer's Avatar
02 Oct 2025 04:55
#917806
In my view Keyster kits are the best out there.  But they contain a lot of stuff you will never use.  What problems are you having with your carbs?
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
02 Oct 2025 05:35
#917808
I only use genuine Mikuni jets.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
