Fuel wont stay Primeed
  • gixxerkidd03
  • gixxerkidd03's Avatar Topic Author
13 Sep 2025 14:43
#917104
Hey all, im looking for some input on what might be happening with my bike, My fuel line wont stay primed. i keep running out of fuel and air is getting trapped. why wont me fuel line stay filled?
New gravity fed petcock
cleaned that carbs
gas cap open
new inline filter
with the fuel line disconnected from  the tank, fuel flows great.
Klein CV34
thanks
1981 KZ750e
  • Nessism
  • Nessism's Avatar
  • Away
Re: Fuel wont stay Primeed
13 Sep 2025 16:32
#917110
Ditch the filter.  If the tank is cruddy, clean it.
  • TexasKZ
  • TexasKZ's Avatar
13 Sep 2025 18:36 - 13 Sep 2025 18:38
#917114
If the filter is designed for a pressurized system, it will cause the symptom you describe. One indication is a paper element. If you want to run a filter, you need one designed for a gravity feed system.
Giving an old  tank a thorough cleaning is always good advice.
This method works well unless there is a bunch of rust.
www.kwick.biz/how-to-flush-your-fuel-tank/
Last edit: 13 Sep 2025 18:38 by TexasKZ.
The following user(s) said Thank You: gixxerkidd03
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Moderator
14 Sep 2025 00:18
#917122
Do you have a problem or is it just that you are seeing “air” in the line
  • Warren3200gt
  • Warren3200gt's Avatar
14 Sep 2025 02:18 - 14 Sep 2025 02:22
#917124
Nothing wrong with running an inline filter but you describe typical symptoms of the inline filter being fitted with flow direction back to front.
If the filter body doesn't have a flow direction arrow on it then rule of thumb is the inlet end fills the outside chamber and outlet end is the inside chamber.
If fitted in reverse you'll have chronic fuel starvation.
Last edit: 14 Sep 2025 02:22 by Warren3200gt.
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Moderator
14 Sep 2025 04:08
#917130
If it is "the wrong way round" throw it away - if you turn it round all the crap that has been filtered will be washed into your carbs
The following user(s) said Thank You: sf4t7, chopper1963, Warren3200gt
  • gixxerkidd03
14 Sep 2025 09:33
#917144
I have a problem with running out of fuel after 15 minutes or so. Fuel stops flowing
1981 KZ750e
  • Warren3200gt
14 Sep 2025 09:53 - 14 Sep 2025 09:57
#917146
That's the symptom of inverted inline filter.
The flow is restricted not shut off, so your bowl fuel level gets gradually lower as the resupply is less than the usage until there's insufficient level in the bowl to run.
Simple visual check if you have the clear body type of inline filter.
If it's not that then you can look elsewhere but check it first before over complicating things.
If it's not that then as its gravity fed only the air breather in the cap being partially/fully blocked creating a vacuum in the tank or crap in the tank blocking the tap could cause the issue.
Also ensure your fuel pipe has continual downward trajectory from the tap. If it's hooped above the tap level you could possibly be creating an air lock in the pipe.
Last edit: 14 Sep 2025 09:57 by Warren3200gt.
  • asphalt900
  • asphalt900's Avatar
14 Sep 2025 11:31
#917154
Also..because You mentioned "rebuilt" the carbs. Make sure YOU didn't plug the float chamber vent lines, just because there is a loose port/barb doesn't mean you should plug it!
The following user(s) said Thank You: Warren3200gt
  • gixxerkidd03
24 Sep 2025 14:08
#917594
Are you guys aware of a carb vent on these cv34’s.
1981 KZ750e
  • Nessism
  • Nessism's Avatar
  • Away
24 Sep 2025 14:45 - 24 Sep 2025 14:50
#917595
The 1981 CV34 carbs vent through a port on the inlet side of the carbs.  The later year CV34's, have two dedicated vent Tee's, one between 1&2 and a second between 3&4.
This is why when a float valve sticks, on the early carbs, fuel flows and fills up the airbox.
Last edit: 24 Sep 2025 14:50 by Nessism.
  • gixxerkidd03
26 Sep 2025 11:45
#917666
Mine don’t have the tee, so they must be 81 style. Can to track down a photo of what I’m looking for. I can’t seem to find any type of vents
1981 KZ750e
