1978 kz650 b2 inside carb bowls fill, but the outside do not, any ideas?
- steve figgins
31 Aug 2025 16:13
cant get the outside carb bowls to fill. inside bowls fill. any way to blow out the fuel rail without removing carb bank
- Warren3200gt
Re: 1978 kz650 b2 inside carb bowls fill, but the outside do not, any ideas?
31 Aug 2025 18:21 - 31 Aug 2025 18:33
If the carbs have been off the rack since it was last running then you have accidentally put carb one in carb four position and carb four in carb one position.
Carb one fuel rail is open on the rh side but blocked on the LH side. Carb four is open on the lh side and blocked on the rh side. So if you've swopped the locations on the rack then you have the open sides facing outwards instead of inwards.
Last edit: 31 Aug 2025 18:33 by Warren3200gt.
- gd4now
- Denco where did you go?
01 Sep 2025 20:14
I look forward to hearing/learning what caused the issue. Warren's solution sounds as good as any I can think of.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
- kimchella
02 Sep 2025 22:43
I second Warren’s thoughts too, as I nearly made that error when putting them together and easily done if you don’t double check 😁😁
KZ650B1 frame number 225
New Zealand
New Zealand
