Float needle O rings
  • Lacher
  • Lacher's Avatar Topic Author
24 Aug 2025 06:37
#916366
Hi, I have a kz1000j 1981 with overflowing carbs.
The original needle and seats were replaced with tourmax replacements. They still leaked. Tried polishing etc but didn't work.
Now I bought a cheap Chinese rebuild kit and they include two small o rings, one rubber one metal. Where do they go ? Do they go on the needle and seat ? I see them in different float rebuild kits but can't find them on diagrams.
  • asphalt900
  • asphalt900's Avatar
  • Away
Re: Float needle O rings
24 Aug 2025 09:01
#916368
Going ChEaP isn't going to resolve your issues unfortunately. Look closely at the float needle tip, really CLOSE with a magnifying glass. You'll see the tip is rough drafted and not a smooth taper. Tourmax products are just Chinese in disguise. The FAT rubber would be for the Pilot slug. The thinnest one would be for the pilot adjust needle washer/spring/oring. The other one, couldn't tell you? Those cheap kits often come with extras of unused stuff. I can say, that brass tapered screw isn't correct!! Looks more like an air adjust screw which these BS34's didn't use. In addition the true J carbs had AIRCUTS for adding extra fuel on deceleration to prevent it from afterfire. Good luck...You'll be back, ha.
  • Lacher
24 Aug 2025 09:41
#916370
Yes I understand, but I just want to try out the float needle and seats, I won't be using the rest. Can't be worse then the ones I have now. I thought those little o rings had something to do with the floats. What is a recommended brand for float needles and seats ? Tourmax were 13 euro a piece so thought they would work but they didn't.
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
24 Aug 2025 12:36
#916374
Have you tried closing them manually ?
Do the floats "float" ?
Are the floats fouling the float bowls ?
  • Lacher
24 Aug 2025 13:05
#916376
I tried closing them manually and tested with my pressure tester but they wouldn't hold any pressure.
I didn't test if they would actually float maybe I should check it out too.
Are the floats fouling the float bowls ? This I don't understand what you mean.
When setting float heights by using the clear tubing method initially they are set good, but slowly the level rises and after an hour they overflow.
  • asphalt900
  • Away
24 Aug 2025 13:40
#916377
You got me at Euros! So apparently You're across the pond. I have containers of this stuff for the BS34's but You're soo far away...
  • Nessism
  • Nessism's Avatar
24 Aug 2025 14:05
#916379
Even good float valves won't hold back fuel for an hour.  And it's the gaskets that sometimes foul the float movement.
  • Lacher
25 Aug 2025 03:31
#916390
If you're sure that they are good I don't mind buying them off you including shipping!
If not I do want to buy new ones but I cannot find a good brand around here that I'm sure that will be good.
@Nessism
I will check out those gaskets, but if those would be stuck I would guess the carbs would overflow almost inmediatly. I understand good floats won't hold fuel completely, but overflowing seems to be a sign of bad float valves.
  • asphalt900
  • Away
25 Aug 2025 05:27
#916391
Be Happy to! But, can You Please post a picture, or several of what You're working on!
The following user(s) said Thank You: Lacher
  • Lacher
25 Aug 2025 06:27
#916394
Of course ! Some pictures that I have on my phone.
  • Nessism
  • Nessism's Avatar
25 Aug 2025 08:42
#916397
I have full O-ring kits for the BS34 carbs, and that small fat O-ring looks nothing like any O-ring I'm familiar with for those carbs.  This same situation repeats itself with various aftermarket O-ring kits sold.  Very strange.
  • asphalt900
  • Away
26 Aug 2025 05:57
#916403
Ed that "larger" o-ring is probably for the Pilot passage plug. They are something like 1.5CS X 3mm. Lacher, instead of me sending You those, try this option. Eventhough some of the K&L float needles have weaker tip springs, have never found that to be the case in this version. The picture shown is the K&L 18-4671 or 16030-1016 2.4 OEM equivalent. I use them all the time and the US vendor is a Great one.
