1980 z1 classic carb swap airbox
  • bikedog
  • bikedog's Avatar Topic Author
22 Aug 2025 16:18 - 22 Aug 2025 16:19
#916337
When swapping the fuel injection to carbs,what airbox will fit.Ive put a set of 26mm carbs from a standard kz 1000 on it.Im thinking if the 1980 Ltd frame is the same this airbox would work.
76 Z1
PSP 1075 stage 2 head
34mm mikunis
suzuki bandit 1250 swingarm
2012 hayabusa frontend and wheels
Last edit: 22 Aug 2025 16:19 by bikedog. Reason: Missing info
  • hardrockminer
  • hardrockminer's Avatar
Re: 1980 z1 classic carb swap airbox
24 Aug 2025 04:00
#916363
I have a 1980 LTD.  The original airbox is rare and hard to find.  I put one on mine initially but had a hard time fitting it to the carbs so I removed it and installed an OEM Z1 airbox.  I also have KZ900 carbs on that bike.
  • bikedog
24 Aug 2025 06:29
#916365
Thanks
appreciate the info 👍
76 Z1
34mm mikunis
