83 KZ550C Progress, But Still Questions
  • DVarney3
  • DVarney3's Avatar Topic Author
20 Aug 2025 07:23
#916261
Howdy again. My previous post was regarding the pilot jets and the air/fuel screws. Thanks again for the replies. I received the Keyster carb kits and have them installed.  I mic'd all the floats at 4 mm. Bike starts under choke, of course, and after warming up idles good. But, bike is reluctant to start moving under its own power, with enough revs it'll go. Rode once down the driveway and down the block, but bogs at low speed. When sitting at an idle it doesn't want to take a quick twist of the throttle, but will slowly rev just fine and revs above 2000 are readily accepted. I checked the timing advance cam and it turns freely.  I'm using air pods from eBay instead of the OEM air box. Also using a non-vacuum petcock from eBay.  So, maybe one of you can save me some time with the following:
1.  I read some previous posts about the air pods. Should I get blockers, go back to original air box, or just what is the best option?
2. Could the petcock be a problem? Should I go back to the original vacuum operated petcock? Better?  I worked it over, but not sure if the diaphram is up to snuff.
3.  Should I go down the road of attempting to adjust air/fuel mixture screws? Suspect that could help.
Thanks again. Much appreciated
  • Nessism
  • Nessism's Avatar
  • DVarney3
Re: 83 KZ550C Progress, But Still Questions
20 Aug 2025 11:16
#916265
Thanks Nessism ! I guess I'll go back and re-evaluate the airbox. Just remember it was a pain to remove, but if that will put an end to the issues its probably worth it.  I did the air pods because I liked the look and the promise of simplicity. Lesson learned.  Appreciate the links to the previous posts. Especially impressed with your 750 rebuild. I didn't do a frame off, but in hindsight I can see the benefit of doing so.  My 550 looked a little worse than yours. Kept outside as well. Paid 250 and probably still too much. But I still believe I can make a decent looking bike once I get the run issues ironed out.  Cosmetics will come last.  Thanks again!
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
20 Aug 2025 12:07
#916266
Don't forget the brakes once it's running before you road test. You are approaching it in the right order by doing the cosmetics last - we have a phrase in the UK "you can't polish a turd" !!!!
  • DVarney3
20 Aug 2025 12:24
#916267
Yes sir. Brakes already been done. Might be my first bike at age 65, but not my first rodeo.
  • DVarney3
20 Aug 2025 14:24
#916270
I'm ordering all new rubber boots along with the filter.  So what's going to be the trick, correct method for getting everything back in place. I'm assuming put the airbox itself back in its place and then somehow fit the four rubber air boots into place between the airbox and carbs? My apologies and hope I'm not asking too much, but any tips on that?
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
20 Aug 2025 20:07 - 20 Aug 2025 20:09
#916279
Each bike is a little different when installing carbs.
My 1000R I just did a week ago went fairly easily, having new boots to the airbox.
How I did it:
First I installed the boots and carb holders. Installed the clamps and spring holders too, loosely.
Attached the throttle cable/s while the carbs were held on the right side.
I should have also installed the fuel and vacuum hoses now, but did not. And they were a pain once the carbs were in.
There was room to bring the carbs in high, above the holders and boots, so I did so.
Once the carbs were slid in far enough, right above thier proper positions, I brought them down and worked them forward into the carb holders.
The boots to the air box, being soft, just got pushed down.
Once the front of the carbs were in the holders far enough, I worked at the boots with my fingers to wrap them around each carb.
Tighten the clamps once all together.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
Last edit: 20 Aug 2025 20:09 by rstnick.
  • H1Vindicator
  • H1Vindicator's Avatar
21 Aug 2025 06:12
#916287
... I'll go back and re-evaluate the airbox. Just remember it was a pain to remove,
old ducts can be hard. new should be soft and pliable. easy to install. brakes. if not already done. replace the rear brake shoes. assuming they're old.
  • DVarney3
18 Oct 2025 17:33
#918158
Reaching out to all you KZ gods and gurus again.  Here's where I stand at the present time and my questions. Carb 3 and 4 were occasionally spilling fuel out the overflows so I pulled them and adjusted the float from 4mm to 5mm. No more overflows, but both cylinders were then cold so my plan is to measure the service level using the clear tube method shown in the FSM. I'm also going to put carb 3 and 4 in the sonic cleaner for good measure. In the meantime, here are my concerns:
1.  Jet needles...is there any need to replace them. My Keyster kits came with them, but I feel the existing needles should be ok. They look ok. I'm reluctant to change. Do they wear badly? The bike only had 12k miles on it.  Guess I can change if it is a must do item.
2.  I've had it with this bloody stock air box and am really considering getting some legit K&N air pods and throw the cheap ones.  If I do K&N am I to increase the size of the main jet and if so, what size? Or, am I to use "air corrector" jets like I've seen in some of the discussions? Are they available for the TK carbs? If so, where are they available?
Again, thanks to you all for all the help you provide to us amateurs !
