I covet your suggestions for a one liter portable fuel tank.
  • Gdizard
  • Gdizard's Avatar Topic Author
  • 12/03/1954
02 Aug 2025 07:10
#915420
I want to buy a one liter portable fuel tank that I can hang from the handlebars or a post. I need this to provide fuel to the carburetor when I am checking them for running condition.
I have seen a few things on e pay but they look like they might be to cheap and therefore not last to long.
Thank you for reading this today !
  • Nessism
  • Nessism's Avatar
Re: I covet your suggestions for a one liter portable fuel tank.
02 Aug 2025 07:28
#915422
I use a chunk of ABS pipe.  2.5" diameter or so, 24" long.  Exact dimensions are not important.  Glue on a matching end cap, then drill and tap for a threaded nipple fitting, for the fuel line.
To hang the pipe, a piece of stiff wire, formed into a hook shape.  When hanging your tank, it needs to be above the carbs, but not too high, or too much pressure head will be applied.
Been using this for years.  Total cost: cheap!  Ha ha.
  • asphalt900
  • asphalt900's Avatar
02 Aug 2025 07:34
#915423
It won't dangle from the bars and certainly not fancy but have had this remote petrol tank for well over 20yrs, works perfect for multiple applications. An old Tecumseh seem brazed tank slightly modified. YES, lawn mower variety. I don't trust those "motion-pro type plastic ultrasound welded tanks. I've a couple new plastic 5gallon tanks that are breaking from the seems.
  • Nerdy
  • Nerdy's Avatar
  • Away
02 Aug 2025 09:21 - 02 Aug 2025 09:21
#915424
I use a Motion Pro aux tank:  www.motionpro.com/product/08-0032
It holds a half-gallon so it's a little bigger than you requested, but it's not huge. Looks like they go for $65.99 these days. :-|
I should mention that this model is just for gravity feed / carbureted bikes. If you want to use it on any fuel-injected bikes you'll need the deluxe version.
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
Last edit: 02 Aug 2025 09:21 by Nerdy.
  • Warren3200gt
  • Warren3200gt's Avatar
02 Aug 2025 09:49
#915425
Been using one of these for about 20 years, still going strong.
I'd imagine it's just a badged generic from China so could be bought loads cheaper.
  • chopper1963
  • chopper1963's Avatar
02 Aug 2025 10:30
#915426
<<< I use a chunk of ABS pipe. >>>
Wow!
  • Nessism
  • Nessism's Avatar
02 Aug 2025 10:55
#915428
Wow!
Thank you!  I'm very ahead of my time, and innovative.
  • asphalt900
02 Aug 2025 11:00
#915429
Had never thought about that, because never needed it but i'm Digging the concept!! One also incorporate an elbow with some sort of translucent hose to show the contents. A quick grab of bits but You can see ED's Idea. Technology straight from the woodpile, ha.
The following user(s) said Thank You: Nessism, Gdizard
  • asphalt900
02 Aug 2025 11:02
#915430
And about 15USD to build or Cheap as Ed noted!!
  • Injected
  • Injected's Avatar
02 Aug 2025 11:56
#915432
I made up this little 1 gallon auxiliary tank stand about 10 years ago with stuff I had lying around the garage, other than the shutoff valve it was free.
1978 KZ650B2 modified project
1981 Z50R Honda tow bike
The following user(s) said Thank You: Gdizard, Wookie58
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
02 Aug 2025 12:23
#915435
I recently bought a plastic mower tank from Ebay for £5 :) won't need it for a while though
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
02 Aug 2025 14:02
#915436
I unlike others do not pics to share. I have tended to use whatever I had on hand. You know the old necessity is the mother of invention thing. Will say I never used a chuck of plastic pipe and I want to tip my hat to you Ed on the idea. I am quite sure I would never of thought of doing so even when I have had lots of said pipe in my junk pile. It just never crossed my mind.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
