Keihin CR smoothbore leak
  • Uncle Freddy
  • Uncle Freddy's Avatar Topic Author
23 Jul 2025 10:51 - 23 Jul 2025 10:53
#914991
guys, finding minimal fuel drip out of my #2 CR smoothbore individual air cleaner bottom ?....enough to put a small runoff spot of fuel on my garage floor overnight under the bike ......key: unless I am riding my '83 650, my petcock is OFF, so I have a teeny fuel leak into my #2 carb's air cleaner with the petcock off (I'm assuming) ....I will of course drain the #2 bowl, remove the bowl & clean it out and let it sit for a bit, but really looking to get any insight as to what is causing this inside the carb, or any check-this / do-this ...thanks for the insight & assist !
youtube.com/shorts/Y2BsigLu8ow?si=baT8bJzVW8qN69cJ
Last edit: 23 Jul 2025 10:53 by Uncle Freddy. Reason: added text
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Moderator
Re: Keihin CR smoothbore leak
23 Jul 2025 11:00
#914993
I would have thought for there to be fuel in the air cleaner the carb is overfilling (float height or float not sealing completely)
The following user(s) said Thank You: gd4now, Uncle Freddy
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
23 Jul 2025 11:30
#914996
You say the fuel is turned off unless you are riding it. Do you have a manual petcock?
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
The following user(s) said Thank You: Uncle Freddy
  • Uncle Freddy
23 Jul 2025 11:34
#914997
yeah, just find it odd that the petcock is off for a few days but I'm still getting fuel into that single air cleaner ....? will drop the bowl and use some light canned compressed air to see if I can dislodge anything ....put it back together, open the petcock, let that carb fill up and see what I get ....thanks Wookie
  • Uncle Freddy
23 Jul 2025 11:39
#914999
I do ...
