Fuel leak
  • Tanknk
  • Tanknk's Avatar Topic Author
Fuel leak
07 Jun 2025 16:32
#913473
Hello All,
I have 1981 KZ650 model and I am working on it to be able to ride this summer. I had carburetor issue last winter. So instead of fixing myself, I got it serviced fully from a Kawasaki dealer.
Today Installed the Carb, Throttle Cabels, and also cleaned the petcock. After everything was assembled, & when I turned the Petcock to Prime position, Pulled the Choke to start the engine,there was a fuel leak from the carb. I am not able to get the engine started (push button start). This happens only when I set the position to Prime. I might need to adjust the idling screw, but I should at least be able to start the engine first and I am not.
I am not sure if this an carb problem or something else. I would appreciate your help. Could this be Carb problem ? ( I hope not, because I paid $$$ to get fully serviced.)
Am i making any mistake on my side as far as starting is concerned. This is my first time working on this motorcycle.
Regards
Narendra
  • ckahleer
  • ckahleer's Avatar
Re: Fuel leak
07 Jun 2025 17:38
#913474
Verify you have the fuel line attached to the carburetor fuel fitting and not to a vent fitting.
The float valves should keep the carburetors from overflowing when the petcock is in the prime position.
1997 ZL600
94 KE100
82 KZ305
74 TC185
  • Nessism
  • Nessism's Avatar
  • Away
Re: Fuel leak
07 Jun 2025 19:14
#913476
Sometimes a float will hang up, causing a leak.  Rapping on the side of the offending carbs float bowl with the handle of a large screwdriver often persuades the float to drop down, and seal again.
