Fitment For 1983 KZ750 L3 Carbs
  • chopper1963
  • chopper1963's Avatar Topic Author
28 May 2025 16:00
#912983
I need the help of a Kawi fitment wizard.
I'm going to try and start with, hopefully, known good carbs from a running motorcycle to replace the carbs on my 1983 L3 750.
What models used the same carbs on the KZ750 L3 and KZ700? I want to open up my search as wide as possible.
I'm going to hopefully find a set on eBay.
  • Nessism
  • Nessism's Avatar
Re: Fitment For 1983 KZ750 L3 Carbs
28 May 2025 16:24 - 29 May 2025 04:56
#912985
It's very unlikely that you will find a set of plug and play carbs on eBay.  Anything you buy will need a full rebuild, cleaning, parts assessment, then assembly with new O-rings and gaskets.
The carbs in question are Mikuni BS34's, tuned for a 750.  The 1982 GPz750 used the same carbs, which makes sense since that bike shares many parts with the L series bikes.
Kawasaki also used BS34's on the 1000 and 1100 bikes, but there are some differences in terms of jetting, needles, needle jets, air jets, slides, etc. They likely could be made to work, but some serious tuning may be needed.
Lastly, the ZX750 family of bikes used BS34's.  Again, some differences.  I suspect they could be adapted easier than the 1000/1100 carbs, though.
Last edit: 29 May 2025 04:56 by Nessism.
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
29 May 2025 08:36
#913022
I am not attempting to confuse anyone or start an argument but I have thought the carbs that came stock on the 750 4s were as follows:
1980 E1 and H1
Keihin cv34
1981 E2, H2 L1
Keihin CV34
1982 E3, L2, H3
Keihin CV34
1982 R1
Mikuni BS34
1983 L3
Keihin CV34
1983 H4
Mikuni BS34
1983 ZX 750 A1
Mikuni BS34
1984 Kz700 A1 kz750L4 ZX750 A2
mikuni BS34
1985-1988 ZX750 A3 - A5
Mikuni BS34
1991 ZR750 C1 (Zephyr)
1992 ZR750 C2 (Zephyr)
1993 ZR750 C3 (Zephyr)
Keihin CVK32
Hello. the gpx600 have CVK32.
Gpx750 have CVK34. Center distance?
ZX750G (Gpz750r ninja) have CVK32
ZG1000 have CVK32
ZR7s have CVK32
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
The following user(s) said Thank You: chopper1963
  • Nessism
  • Nessism's Avatar
29 May 2025 09:46 - 29 May 2025 09:48
#913024
These two are flip-flopped...
1983 L3
Keihin CV34 - BS34
1983 H4
Mikuni BS34 - CV34
Also realize, the ZX750 bikes BS34 are different from the earlier version BS34
Last edit: 29 May 2025 09:48 by Nessism.
The following user(s) said Thank You: gd4now
  • chopper1963
29 May 2025 10:13
#913026
Thanks so much! I am sure that this info will be of great use to many!
D
The following user(s) said Thank You: kimchella
  • gd4now
  • gd4now's Avatar
29 May 2025 10:23
#913027
Thanks for the correction Ed.
1977 KZ650 B1
  • chopper1963
29 May 2025 11:12
#913033
Anyone know where to find a PDF of the service and or Clymer manual for the 1983 KZ750L3?
  • gd4now
  • gd4now's Avatar
29 May 2025 11:32
#913038
There may be one in the filebase located on this site. I did not go hunting for it so do not know if it is here or not.
But you can find lots of info and manuals and parts list here
kz.bike-night.com/
1977 KZ650 B1
