Leaking fuel Petcock
- Oldzeuski
24 May 2025 14:07
My kz650 was leaking fuel so I pulled the petcock and ordered a rebuild kit. When I installed the kit I noticed a few things that don’t make sense.
First of all, the fuel selector lever is not held firmly against the rubber seal behind it. It appears the plate with fuel markings is meant to hold this in place, but it actually allows the lever to be pulled out just enough that the rubber seal behind it isn’t able to properly seal. It’s almost like the seal is .030 too thin. But I put the original back in and it still had this issue. Very Strange.
Second, after installing the petcock with all new parts, it still leaked. I was able to verify this is due to the internal spring not pressing enough on the diaphragm. The fuel was leaking by the o ring as it should when vacuum is applied and the diaphragm compresses the spring, even tho there was no vacuum.
The spring is installed correctly, but on a bench set up I was only able to stop the flow by using my thumb and putting force on the diaphragm while the cover was removed. Far more force than the spring can exert.
I even went back to the original o ring and diaphragm, thinking maybe the rebuild was junk and too large or small and wasn’t fitting correctly to make a good seal. Same problem.
honestly I’m amazed it didn’t always leak, but it worked fine until this season.
I bought a new OEM unit to replace this one. But I’m just curious if anyone knows why this one is leaking.
the pictures are the petcock. The one with the fuel lever off is showing the rubber seal.
- Busy
Re: Leaking fuel Petcock
24 May 2025 21:51 - 24 May 2025 21:54
Did you polish the seating area that the oring is supposed to seal against? If there is any pitting or roughness in the surface, the oring will not seal well.
Also, there should be a spring washer between the retaining plate and the selector lever that forces the lever against the oring.
www.partzilla.com/catalog/kawasaki/motor...uel-tank-81-82-h1-h2
Last edit: 24 May 2025 21:54 by TexasKZ.
The following user(s) said Thank You: SWest, Gdizard, Oldzeuski
- Oldzeuski
25 May 2025 08:30
Well the spring washer was missing apparently. It didn’t have one when I pulled the petcock apart tho so how it never leaked before is a mystery.
I’ll try polishing the o ring surface and see what happens. I’ve got a new petcock coming either way so this is just going to be a backup I suppose.
- ckahleer
26 May 2025 18:54
Search "wave spring washer" on E-bay. They come in all sizes.
1997 ZL600
94 KE100
82 KZ305
74 TC185
94 KE100
82 KZ305
74 TC185
The following user(s) said Thank You: ThatGPzGuy, Wookie58
- Oldzeuski
02 Jun 2025 07:53
Thank you. If the new one is also missing this washer I will order a replacement.
I polished the interior hole where the diaphragm and o ring are supposed to fit into. The o ring still does not fit. I’m guessing it never actually sealed and only recently began leaking severely enough that I was able to see the puddle of gas before it evaporated. Probably from ethanol deteriorating the rubber.
I may end up adding an inline cutoff so this can’t ever happen again.
- Busy
04 Jun 2025 17:50
If the oring does not fit, perhaps it is the wrong one.
- asphalt900
05 Jun 2025 03:38
These diaphragm petcocks can be a hassle. Look closely, i mean REALLY close at the "cone" sector where the diaphragm protrusion with o-ring resides. Should be a machine like finish with NO scratches/burrs. Buying a "kit" can sometimes cause false hope. Try a #007 oring, that's generally what they require. I do a lot of the Kawasaki H1-H2 series petcocks and they use the same.
- ThatGPzGuy
05 Jun 2025 05:32
All of my bikes have their original petcocks. They can be made to work without leaking. I've posted this before, but this is the tutorial I usually reference. It's for a Yamaha but they are very similar to Kawasaki petcocks.
Rebuilding Yamaha Petcocks
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
The following user(s) said Thank You: SWest, kimchella, Glenn_22
- Glenn_22
16 Jun 2025 15:07
Thanks for posting that link to the petcock rebuilds, very helpful.
I've followed it for the cleaning and polishing but I'm still stuck on which way the Valve Gasket should face, the new gasket I bought has two different faces, one has a recess and the other a small raised section, do you know which way it goes?
1981 Kawasaki Z1000J1
1983 Yamaha RZ350
1986 Yamaha TZR2501KT
1995 Yamaha TZR250SPR Sugo
2022 Husqvarna TE250i
1983 Yamaha RZ350
