Dust shields
  • mvent
  • mvent's Avatar Topic Author
Dust shields
16 May 2025 17:23
#912479
Any availability of part number 16055-002 dust shields ? TIA
76 KZ900
76 XLCH
78 KZ1000
04 FLSTFI 120 ci
  • Nessism
  • Nessism's Avatar
  • Away
The following user(s) said Thank You: mvent, asphalt900
  • asphalt900
  • asphalt900's Avatar
Re: Dust shields
17 May 2025 03:41
#912489
By chance do you have at least one that didn't fall apart and can use a templet? I always just make them myself out of fiber gasket material. A pair of scissors and hole punch are all that's needed. Nothing critical or total sealing, just keeps out the biggest amount of grime.
The following user(s) said Thank You: mvent, Gdizard
  • Cra-z1
  • Cra-z1's Avatar
Re: Dust shields
17 May 2025 07:20
#912491
A lot of the time they have some small cracks but usable. You could try stamping some from an old bicycle inner tube. If you have the old ones clean them up and install them with this.
www.amazon.com/MERCURY-92-86166Q-1-Bello...-2281435178098&psc=1
  • mvent
Re: Dust shields
17 May 2025 16:42
#912521
Thank you all for suggestions, many to think about.
76 KZ900
76 XLCH
78 KZ1000
04 FLSTFI 120 ci
  • asphalt900
Re: Dust shields
18 May 2025 03:59
#912533
Cra-Z1, does that Bellow adhesive remain "rubbery" after curing? I've been searching for the product used on a lot of Honda float bowls to hold the oring. It's a brownish color and even after 50yrs still is pliable.
  • Cra-z1
  • Cra-z1's Avatar
Re: Dust shields
18 May 2025 10:28
#912549
Well it's somewhat pliable, like you can get a fingernail to press into it. When you use it on the lower unit of the boat you smear it on the sealing rings and of course the bellows if your replacing it.
