How to run fuel lines to carbs
- RetroRipper
07 May 2025 09:33
How to run the fuel lines from the petcock (2 ports) to a set of dual carbs. There is one fitting in between both carbs that connect the bowls, and there is port on each side of the carbs. Also, i'm a visual learner and I have found no video on this.. TIA!!!
Re: How to run fuel lines to carbs
07 May 2025 10:19
Do you have the factory service manual for your bike? You can download it here, then look at all the pictures.
And BTW, you didn't mention what bike, year, model.
The following user(s) said Thank You: Warren3200gt
- RetroRipper
07 May 2025 10:39 - 07 May 2025 10:52
1976 Kawasaki KZ400-D. It was a set of 77' Keihin dual carbs. Also, what type of materials hoses can I use for fuel line? Can clear vinyl work?
Last edit: 07 May 2025 10:52 by RetroRipper.
- gd4now
- Denco where did you go?
07 May 2025 10:51
In your other post I asked what if anything is stamped around the petcock lever? This may help to determine if it is a manual or vacuum operated petcock. If it is a dual outlet manual one it would require a "Y" joint to place both into the one inlet on the carbs. Or you could remove the one fuel inlet between the carbs and make use of individual inlets on each carb. If on the other hand the petcock is a vacuum operated one, then one of the 2 ports on the petcock needs to be connected to a vacuum source to function correctly. Again in your other post it was pointed out via a pic where the vacuum ports are on the carbs.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
- RetroRipper
07 May 2025 11:44 - 07 May 2025 11:46
You need to provide more information here. Some photos, something. We are flying blind.
As near as I can tell, by looking through the service manual (did you download it?), the petcock has two fuel feeds, one of which goes to each carb. There are also vent lines, which stay open, and drain/overflow tubes on the float bowls. And NO, you cannot use clear vinyl tube for fuel line.
Last edit: 07 May 2025 11:46 by Nessism.
The following user(s) said Thank You: asphalt900, Gdizard
- asphalt900
07 May 2025 12:14
But You're working on a Hack-Saw Henry Special Edition so yes use that clear hose from the hardware store, it'll work for about a month till it hardens stiffer then a rutting 14yr old fella, ha.
- RetroRipper
07 May 2025 15:48
Thank you for information. I do not see the link for it.
07 May 2025 16:10 - 07 May 2025 16:31The manual is in Filebase. Easy to find.Thank you for information. I do not see the link for it.
Last edit: 07 May 2025 16:31 by Nessism.
- RetroRipper
08 May 2025 07:41
Thank you for all your information good sir!
