gas resistant (proof?) adhesive
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
Re: gas resistant (proof?) adhesive
25 Apr 2025 12:30
#911732
I am asking a question with this suggestion. I do not know enough about the heat shrink tube to say it could work. But have had a thought of cutting a ring of the correct tube and use it like the ring you had to cut off on the stock setup. Once in the correct location heat it and it may seal it to the slide?
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
The following user(s) said Thank You: 82KZ305Belt
  • 82KZ305Belt
  • 82KZ305Belt's Avatar Topic Author
25 Apr 2025 14:20
#911738
That's a thought. I've never used it but they do make Viton heat shrink. I wonder if it might work better as an underlayment though, along the lines of the JB weld idea but doesn't need a lathe (that I don't have anyway).
81 KZ650 CSR
77 KZ650B (not in my paws yet)
82 KZ305 CSR
  • Cra-z1
  • Cra-z1's Avatar
25 Apr 2025 20:11
#911745
If you try the heat shrink go with the Marine type, it has a glue/sealant in the inside. That may be a good idea.
  • 82KZ305Belt
27 Apr 2025 14:14
#911807
I'm reading on several other bike forms, e.g. www.kawasakiforums.com/forum/klx-250s-71...ragm-expanded-40085/   and forum.concours.org/index.php?threads/car...cuum-diaphragm.4393/
That hot water shrinks diaphragms. Usually in the context of ones that were exposed to carb cleaner, which enlarges them, which mine have not.
But does hot water work in other cases too, where it was made too big? And is the shrinkage permanent? I'm a bit wary of overshrinking it so the top end doesn't fit properly under the cap.  I might have my old pair I can test with but it would be nicer to know without potentially destructive tests...
81 KZ650 CSR
82 KZ305 CSR
  • Nessism
  • Nessism's Avatar
27 Apr 2025 15:38
#911809
Hot water won't shrink the diaphragm.  In use, on a hot day, the carbs, and diaphragms will get quite toasty, near boiling water temp.  If the diaphragms shrink when hot, they wouldn't fit the carbs after the first hot ride.
  • 82KZ305Belt
27 Apr 2025 17:54
#911812
I agree. Sounds fishy.
81 KZ650 CSR
82 KZ305 CSR
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
29 Apr 2025 17:00
#911888
I always fix leaking fuel tees with heat shink tubes, they never leaked again......
The following user(s) said Thank You: 82KZ305Belt, Gdizard
  • 82KZ305Belt
18 May 2025 09:48 - 18 May 2025 09:51
#912546
At the last minute I decided to go with Seal All, because I had some on hand, but then I had a thought. I googled the operating temperature range and it only goes up to 150 degrees F.  Thought that might be pushing my luck, but I don't know how hot that part of the carb gets. I ended up using non-marine heat shrink (no marine available locally in the right size) to widen the groove where the diaphragm rides. It should be good to 200-250 F. One layer was sufficient to make the diaphragm nice and snug, so this should fix any diaphragm related problems.
Hoping for nice weather someday so I can test it. After my last ride last fall it wouldn't start however, so hopefully I can solve that before nice weather arrives. Anyway I think the heat shrink solution should be a winner. It will sure as heck be a massive improvement over the sloppy loose way they fit previously.
81 KZ650 CSR
82 KZ305 CSR
Last edit: 18 May 2025 09:51 by 82KZ305Belt.
  • 82KZ305Belt
18 May 2025 18:16
#912564
Success! Or at least partial success...the sun came out, I managed to start it, warmed it up, and I took it for a short cold ride. Acceleration seemed good and I was able to get it above 50mph pretty easily, which was the main problem I attributed to leaky diaphragms that I was hoping to fix. But (why is there always a but?) it is running lean and I had to keep it partway choked. So I guess its now back to my 157th carb tinkering session. I think I will just go back and do everything the manual prescribes from scratch, as if I had just cleaned the carbs (but without cleaning them. I think 157 is enough).
81 KZ650 CSR
82 KZ305 CSR
The following user(s) said Thank You: kimchella, HZ-237
