VM22SS - Second Pilot Jets
  • xbr500
  • xbr500's Avatar Topic Author
15 Apr 2025 07:43
#911332
(Previously posted in error to Chassis)
What’s going on here?
Bought nice running KZ650 DA1 with poor tickover. VM22SS non-pumpers.
Removed and stripped carbs. Only one had a second pilot jet (50).
Simultaneously I spotted spare carbs on ebay at a nice price.
Stripped these and AGAIN found only one carb with a second pilot jet!
Coincidence? Normal? Or what?
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
Re: VM22SS - Second Pilot Jets
15 Apr 2025 08:39
#911334
Hi, please try and keep to one thread per topic. Guys get frustrated trying to follow multiple threads on the same topic - I have removed the other three versions of this post
The following user(s) said Thank You: Nessism, Warren3200gt
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
15 Apr 2025 08:42 - 15 Apr 2025 09:03
#911335
First let me preface this post by saying I do not claim to be an expert on the topic. Will say I have only been able to find info that suggests all of the vm 22 and vm24 carbs that have only a pilot (fuel) screw and  came stock on the 650s have the additional #50 jet.
Which carb did your current set have the additional jet located in? All of the sets I have had apart had the additional jet in all the carbs. Did the second set have it in the same carb? I can not see what advantage having the jet on only one carb would provide. I in the past have removed them from both 22s and 24s and have not noticed any difference in function, via the seat of my pants.
I might ask what the ID stamped on the set of carbs (both) is? It should be located on the flange below the choke lever on carb #1 or in the same location on the outside of carb #4. I would assume either 1026 or 1046. The should be in 2 lines as follows.
102
6 (may be other letters or numbers after it)
or
104
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
Last edit: 15 Apr 2025 09:03 by gd4now.
  • Nessism
  • Nessism's Avatar
