1974 Kawasaki Kz 400 Float bowl Gaskets
  • Newsman
  • Newsman's Avatar Topic Author
05 Apr 2025 05:27
#910971
Hello can anyone Recommend some decent carb repair kits with float bowl gaskets that fit? I have tried 2 Ebay specials, but the gaskets are too small unless its just me being incompetent, I have tried sticking them down with gasket cement which I don't like doing but I can get them in 3 of the 5 corners but then the other side pops out,
Thank you
Andre
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
Re: 1974 Kawasaki Kz 400 Float bowl Gaskets
05 Apr 2025 06:12
#910972
I have not worked on a set of these carbs (Keihin CVB 36) in many years, so take this info with that thought in mind. From info I can find the bowl gasket is Kawasaki part# 16019-024. A quick search on line produced several locations that claim to have them.
www.genuinekawasakiparts.com/oemparts/p/...24/o-ring-float-ball
www.partzilla.com/product/kawasaki/16019-024
www.countrycat.com/kawasaki-parts/kawasa...24-o-ring-float-ball
www.kawasakipartsnation.com/oemparts/p/k...24/o-ring-float-ball
www.amazon.com/Shaped-Ring-Float-Bowl-Gaskets/dp/B01L0BCUOQ
Now having said all of that I do not know if any of the links do have them in stock or not, but they claim to have them. Further I do not know if the items they have are any different than the ones you currently have.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
  • TexasKZ
  • TexasKZ's Avatar
05 Apr 2025 06:18 - 05 Apr 2025 06:25
#910973
Partzilla shows it as NLA, but Webike shows it in stock and tariff free!
japan.webike.net/ps/16019-024/#!search&p.k=16019-024
Looks like CMS also has them.
www.cmsnl.com/search/?section=all&q=16019-024&tab=
In case you are not familiar with these three companies, they sell genuine Kawasaki factory parts. They also have some aftermarket stuff, especially Webike. You may want to hold tightly to your wallet. The temptations can be powerful........
Last edit: 05 Apr 2025 06:25 by TexasKZ.
  • Newsman
05 Apr 2025 06:48
#910976
Thank you so much thats very helpfull I should have mentioned I am in the UK  but I will look at those and find out .
  • Newsman
05 Apr 2025 06:55 - 05 Apr 2025 06:59
#910977
Hello thank you I should have mentioned I was in the UK it seems webike will ship to the Uk CMS have them and they are in Europe the price of them is about 13 pounds nd they want about 14 pounds to post them which I felt was a bit much but if all else fails I will try them
The UK Amazon has some I may try them
Last edit: 05 Apr 2025 06:59 by Newsman.
  • Nessism
  • Nessism's Avatar
  • Away
05 Apr 2025 10:45
#910987
The proper size is 2.0 x 67 (thickness x ID).  Use super glue or similar, to hold the O-ring in the float bowl groove, until it holds in place.  I have O-ring kits for the Keihin 750 carbs, and the Keihin 400/440 carbs seem to use the same O-ring.
  • Newsman
05 Apr 2025 11:05
#910988
Thank you, I did glue the O rings I had in place I have put the carbs back together now and if they hold fuel that will be great, if I needs some I wil contact you thank you for answering
