Airbox to carb rubbers
- Newsman
02 Apr 2025 08:57
Hi
I have a 1974 Kz400 and the carb to the airbox rubbers are cracked does anyone know of any of these from alternate bikes as I cannot find any for the 400 I was hoping a different model may have the same or have some nearley the same which I could use for replacements
Thank you
Andre
Thank you
Andre
- Warren3200gt
Re: Airbox to carb rubbers
02 Apr 2025 09:14 - 02 Apr 2025 09:15
Airbox to carb rubbers are not super critical to optimum running unlike the carb to head rubbers which most definately are.
You could just glue any splits up with no detriment to running.
Last edit: 02 Apr 2025 09:15 by Warren3200gt.
- Newsman
02 Apr 2025 09:16
Hi Warren
Thanks for the advice I will get the superglue out I would like to use the original filter as I dont fancy the pod type filters
Andre
Andre
03 Apr 2025 04:36
I wonder if rubber cement would be a better choice here since it remains flexible after it dries?
- Cra-z1
03 Apr 2025 07:30 - 03 Apr 2025 07:32
A better choice would be Bellows adhesive used in the marine industry. I use this stuff on a lot of things. Kind of like rubber cement only better. It seals the rubber bellows to the drive.
www.wholesalemarine.com/mercury-mercruis...OEAQYBSABEgJ6QPD_BwE
Last edit: 03 Apr 2025 07:32 by Cra-z1.
The following user(s) said Thank You: TexasKZ
03 Apr 2025 08:48A better choice would be Bellows adhesive used in the marine industry. I use this stuff on a lot of things. Kind of like rubber cement only better. It seals the rubber bellows to the drive.
I'm not sure how sensitive the KZ400 is, but there are some bikes that will not run right with air leaks in the airbox and/or the boots.
- Nerdy
03 Apr 2025 11:21 - 03 Apr 2025 11:22
I haven't tried this, but have read of people who cut short sections of radiator hose to connect the airbox to the carb.
If each carb's weight is being supported primarily by the intake boot, this seems like it would work.
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
Last edit: 03 Apr 2025 11:22 by Nerdy.
- Newsman
03 Apr 2025 13:03
Thank you I will have to look for something like that in the UK brilliant !!
- Newsman
03 Apr 2025 13:04
I was concerned about that previous bikes I have owned were very fussy about air cleaners which why I dont really want to go to pod type filters
- Newsman
03 Apr 2025 16:13I would be concerned about losing the bellmouth in the airbox ?I haven't tried this, but have read of people who cut short sections of radiator hose to connect the airbox to the carb.
- Injected
03 Apr 2025 16:57Continental sells a rubber adhesive that bicycle mechanics use to glue tubular race tires onto rims (think Tour De France) they call it rim cement, but you could use any other vulcanizing cement. You can buy it at most good bicycle shops.Hi Warren
Andre
1978 KZ650B2 modified project
1981 Z50R Honda tow bike
