Floats and float pins
- jstry11
24 Mar 2025 13:29
Anyone have a suggestion on where to source new floats and float pins for teikai 22 carbs?
I can't seem to find the floats anywhere.
for pins I'm at the point where I may make my own from brass or stainless rod of the same diameter and cutting them to length.
thanks
thanks
82 KZ 550
Re: Floats and float pins
24 Mar 2025 16:12
There are some on ebay. Not cheap. Why do you need "new" floats? You might be better off buying a cheap set of parts carbs to get the parts you need.
The following user(s) said Thank You: Gdizard, jstry11
- jstry11
25 Mar 2025 08:45
I don't need floats, (especially with the eBay prices!) but never hurts to see if someone's got a line on a set that doesn't cost an arm as a leg, as far a pins, couldn't tell you how they got all bent up but boy they are!
82 KZ 550
