KZ900 carburetor parts wanted to buy … Where?
  • increasing
  • increasing's Avatar Topic Author
  • curious to know
24 Mar 2025 11:05
#910457
Is there anyone selling carburetor parts for the KZ900, the parts I want to buy are 6 pc "92071-102 grommet carburetor body linkage" as shown in the pictures. It may also be interesting to buy blind plugs 2 pc "16039-042 cap rubber" as in the picture.
increasing :)
1974 Kawasaki Z1A 900, 1976 Kawasaki KZ900-A4, 1987 Kawasaki GPX750R
  • Injected
  • Injected's Avatar
Re: KZ900 carburetor parts wanted to buy … Where?
24 Mar 2025 11:36 - 24 Mar 2025 11:40
#910463
Both are NLA from Kawasaki but was able to find them easily by typing "Kawasaki" then the part number on Ebay.
Items # 176241207230 and 286285904258.
1978 KZ650B2 modified project
1981 Z50R Honda tow bike
Last edit: 24 Mar 2025 11:40 by Injected. Reason: info
The following user(s) said Thank You: increasing, Rolf1976_KZ900
  • Rolf1976_KZ900
  • Rolf1976_KZ900's Avatar
24 Mar 2025 11:42 - 24 Mar 2025 11:46
#910464
No eBay APP ID and/or Cert ID defined in Kunena configurationMaybe try search for suzuki gs carb parts ? i think some of them use same carbs
just did a quick search and found these maybe they fit?
Last edit: 24 Mar 2025 11:46 by Rolf1976_KZ900. Reason: adding link ebay
  • asphalt900
  • asphalt900's Avatar
24 Mar 2025 11:44
#910465
I have some but in the Suzuki variation. Some Kawasaki ones had a "skin/teflon" inner sticker where the rubber meets the shaft. But non-essential. Kawasaki nor Suzuki made these, generic Mikuni issue. But this Suzuki part number will give you "increasing" availability for bits needed, same stuff and function. Suzuki # 13556-45010 for the inner 6. You're Far-F  ar away from me so wouldn't be cost effective to send unfortunately. Mailing shite abroad is increasingly expensive these days!!
  • Rolf1976_KZ900
24 Mar 2025 11:50
#910466
By the way.... are these grommets just for dust or do they also seal air so a vacuum leak will inpact carburetion?
  • asphalt900
24 Mar 2025 11:58
#910468
More so for diverting crud but may have some impact on the slide hole at lower RPMs? Have to remember when syncing, caps are off to perform that maintenance.
  • zed1015
  • zed1015's Avatar
24 Mar 2025 13:29
#910476
Yes! Just dust seals.
The following user(s) said Thank You: Gdizard, increasing
  • increasing
  • curious to know
25 Mar 2025 04:10
#910502
Thanks for good and clarifying answers 👍
increasing :)
  • increasing
  • curious to know
25 Mar 2025 04:16 - 25 Mar 2025 04:17
#910503
post=910465 userid=19828I have some but in the Suzuki variation. Some Kawasaki ones had a "skin/teflon" inner sticker where the rubber meets the shaft. But non-essential. Kawasaki nor Suzuki made these, generic Mikuni issue. But this Suzuki part number will give you "increasing" availability for bits needed, same stuff and function. Suzuki # 13556-45010 for the inner 6. You're Far-Far away from me so wouldn't be cost effective to send unfortunately. Mailing
Do you have 6 of these?
increasing :)
Last edit: 25 Mar 2025 04:17 by increasing.
  • asphalt900
25 Mar 2025 04:57
#910504
Unfortunately no, just the two shown. But there's a cat on ebay "motomantra" that has a set for something like 20USD.
  • DOHC
  • DOHC's Avatar
  • Those Doe-Hawks really go!
25 Mar 2025 05:34
#910509
Here is another source:   www.siriusconinc.com/m/products-detail.php?product_id=123335
I have used a few sets of these and they work well.
I also found a bunch of similar VM replacement parts at JetsRUs.com, but it looks the number of available parts they carry has dropped.  I wonder if some of their supply dried up when Sudco closed.
My dad's '74 Z1
'00 ZRX1100
