Jetting for stock air box and Vance & Hines header
- david3378
15 Mar 2025 19:49
What jetting is best for a 1976 kz900. Stock air box and Vance & Hines header? Thanks
- Warren3200gt
Re: Jetting for stock air box and Vance & Hines header
16 Mar 2025 03:32
Air intake effects jetting far more than exhaust. Four strokes just want to get rid of exhaust gases ASAP. As long as you plan a free flow tail on the headers you'll be fine with stock jetting.
- asphalt900
16 Mar 2025 09:58
Yes as You've already stated. You've kept the original "Golden" airbox! As Warren stated, You want that combination, intake constriction is far more important then choice of Exhaust. While Vance didn't flow quite as good as an ole Kerker, keep the original jetting of pilot 17.5. Going to a 20 on stock engine will result in sluggish overfueled scenario. I'm assuming You have the original Z1200 1976-77 carbs? Should have, as original, 5DL31-3 Jet Needle and 0-6 Needle Jet. Standard main is 115 and pilot 17.5. Didn't mention a packed baffle, loose or pulling it out altogether? Assemble and check for full WOT.
- david3378
16 Mar 2025 10:13
Packed Vance now. I plan to remove the packing and open it up. I restore 2 strokes. I’m going 4 stroke now. Any advice would be appreciated. Thank you
- david3378
- gd4now
- Denco where did you go?
16 Mar 2025 14:34
Agree many 4 into 1 systems do not require jetting changes but you will not know until you try
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
