Choke plungers
  • kimchella
  • kimchella's Avatar Topic Author
Choke plungers
05 Mar 2025 09:48
#909695
I received my 1st set of choke plungers that I have had new seals installed by Zed1015.
Awesome job Zed 👍 really well installed and worth every penny. My next set will be in the post tomorrow to be done.
These plungers cause so many running and starting problems and are often discussed on here.
Thanks Zed.
Rich.
NZ
KZ650B1 frame number 225
The following user(s) said Thank You: zed1015, gd4now, Gdizard, Wookie58, Rolf1976_KZ900
  • Saablord
  • Saablord's Avatar
Re: Choke plungers
05 Mar 2025 11:49
#909696
Thanks for reminding me that I need to find the punches I made for this. I have some bs34 carb plungers to fix.
This is probably the first step to using any old set of carbs, imo. Good stuff.
The following user(s) said Thank You: Nessism, Gdizard, kimchella
  • zed1015
  • zed1015's Avatar
Re: Choke plungers
06 Mar 2025 00:04 - 06 Mar 2025 02:19
#909713
Thanks Zed.
Rich.
NZ
Thanks.
Will watch the post for them.
Last edit: 06 Mar 2025 02:19 by zed1015.
The following user(s) said Thank You: MFP-Joe, Gdizard, kimchella
  • MFP-Joe
  • MFP-Joe's Avatar
  • forever 18 when on my bike
Re: Choke plungers
10 Mar 2025 14:26
#909908
Hi Rob,
seems like your refurbished choke plungers do their job good and problemless. Thanks again !!!
Greetings, Joe
The following user(s) said Thank You: zed1015, Gdizard, kimchella
  • kimchella
Re: Choke plungers
28 Mar 2025 16:58
#910681
Hi Rob, (zed1015), the newly refurbished second set of choke plungers have arrived safely in sunny NZ. Awesome service again, thank you.
Rich.
The following user(s) said Thank You: zed1015, MFP-Joe, Scirocco
