KZ 900 Carburator has internal leak.
- Kaw-boy 900
- Let the Good ''Old'' Time Roll !
01 Dec 2024 08:11 - 01 Dec 2024 15:56
The subject title should be change for KZ 900 carburator gas supply restriction. As per issue discovery !
Hi, I did a floats adjustment with clear tubes. I noticed that carburetor 3 and 4 have an internal leak. Once the fuel level has filled the bowls and the float valves are closed, the fuel line supply keep feeding the carburators for app 1 oz or the equivalent of 1-1/2 time the lenght of my fuel line supply set up.
Note: I have new float valves and seats.
Could it be a starter plunger issue ? And could this explain the small backfire at start up ??
Kawasaki and other bike ownend.
S1 250 triple 1973
H1, 500 triple 1975
LTD 1000, 1982
Ninja 1000R 1987
Ninja ZX12R 2006
KZ900 1976. My BB !
Yamaha RD 350 1973
Ducati 1098 2007
Harley Softail 2009 For sale !
S1 250 triple 1973
H1, 500 triple 1975
LTD 1000, 1982
Ninja 1000R 1987
Ninja ZX12R 2006
KZ900 1976. My BB !
Yamaha RD 350 1973
Ducati 1098 2007
Last edit: 01 Dec 2024 15:56 by Kaw-boy 900.
- asphalt900
Re: KZ 900 Carburator has internal leak.
01 Dec 2024 08:40
When You say keeps feeding the carbs, meaning? Is it coming thru the venturi's or spilling out?? Please elaborate.
- Kaw-boy 900
01 Dec 2024 09:33 - 01 Dec 2024 12:26No external leak. When gas level reach the correct level inside the the bowl: (1/8'' below the top of the bowl) the float valve close: (in green)
but the remaining gas in the fill line: (in red) will slowly continue to drain into the cabs : if full, it will drain competely and if I do a seconf fill, only 1/2 will go into the carbs. The remaning gas in the fill line will stay at same level.
That mean the floats work correctly, but there is a leak somewhere before the float valve and the gas go somewhere in the carb
S1 250 triple 1973
H1, 500 triple 1975
LTD 1000, 1982
Ninja 1000R 1987
Ninja ZX12R 2006
KZ900 1976. My BB !
Yamaha RD 350 1973
Ducati 1098 2007
S1 250 triple 1973
H1, 500 triple 1975
LTD 1000, 1982
Ninja 1000R 1987
Ninja ZX12R 2006
KZ900 1976. My BB !
Yamaha RD 350 1973
Ducati 1098 2007
Last edit: 01 Dec 2024 12:26 by Kaw-boy 900.
01 Dec 2024 12:52
It sounds like you may have an air bubble in the supply line, and as the bubble clears, it visually appears that the fuel is continuing to enter.
Simple fact is that if fuel was entering the carbs, you would see it in the clear tubes.
The following user(s) said Thank You: Kaw-boy 900
- Kaw-boy 900
01 Dec 2024 14:10 - 01 Dec 2024 16:01
I think I've found the problem! I connected a hose on the T and blew into it. Carb 1-2: I hear the air blown with a slight restriction.
Carb 3-4: It almost block. Air go in slowly... like the gas in that fill line.
See how the T was installed with a sealant (by previous owner) it must be a restriction not far away.
I guess I have to replace these T's and find the blockage. Any recommendation for good T's. ?
S1 250 triple 1973
H1, 500 triple 1975
LTD 1000, 1982
Ninja 1000R 1987
Ninja ZX12R 2006
KZ900 1976. My BB !
Yamaha RD 350 1973
Ducati 1098 2007
S1 250 triple 1973
H1, 500 triple 1975
LTD 1000, 1982
Ninja 1000R 1987
Ninja ZX12R 2006
KZ900 1976. My BB !
Yamaha RD 350 1973
Ducati 1098 2007
Last edit: 01 Dec 2024 16:01 by Kaw-boy 900.
- Cra-z1
01 Dec 2024 16:02
I would say you need new tees. Someone tried to use the old ones wrapping teflon tape around them.
- Kaw-boy 900
02 Dec 2024 07:01 - 02 Dec 2024 07:02
Found that issue ''Carb 3-4: It almost block. Air go in slowly... like the gas in that fill line''
The restriction was caused by float # 4 being to low and touching the bottom of the bowl. It was almost closing the float valve.
S1 250 triple 1973
H1, 500 triple 1975
LTD 1000, 1982
Ninja 1000R 1987
Ninja ZX12R 2006
KZ900 1976. My BB !
Yamaha RD 350 1973
Ducati 1098 2007
S1 250 triple 1973
H1, 500 triple 1975
LTD 1000, 1982
Ninja 1000R 1987
Ninja ZX12R 2006
KZ900 1976. My BB !
Yamaha RD 350 1973
Ducati 1098 2007
Last edit: 02 Dec 2024 07:02 by Kaw-boy 900.
- gd4now
- Denco where did you go?
02 Dec 2024 11:57
Good find! Ins't working on old machines an interesting thing? One tends to have to touch, listen and exam the entire machine. Not like new equipment where a computer does that? I certainly think so but just what do I know? I know I am just old.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
The following user(s) said Thank You: Injected
- Kaw-boy 900
02 Dec 2024 13:50 - 02 Dec 2024 15:37
Thanks, It's a chace to be old because otherwise we would have no clue to find out what's going on!
At least with old thing
But I still have an issue with carb # 4 : When the gas goes in the bowl, the clear tube stop rising at some point (valve close I guess) then slowly rise app 5 mm / 1/4''. Last time I tried, it leaked by the over flow.
A funny thing.... Maybe not!
I took the #1 carburetor float which has the old float valve and seat that work perfectly and installed it in #4 which has the new valve and Keyster seat and guess what! No gas entered the carburetor
just like the previous issue with #4)
Comparing the 2 seats, they are 1 mm difference and the valve pin at the end are also longer. Enough to have this problem
Before doing the clear tube check, all floats were set at 26 mm / 1.02''
S1 250 triple 1973
H1, 500 triple 1975
LTD 1000, 1982
Ninja 1000R 1987
Ninja ZX12R 2006
KZ900 1976. My BB !
Yamaha RD 350 1973
Ducati 1098 2007
S1 250 triple 1973
H1, 500 triple 1975
LTD 1000, 1982
Ninja 1000R 1987
Ninja ZX12R 2006
KZ900 1976. My BB !
Yamaha RD 350 1973
Ducati 1098 2007
Last edit: 02 Dec 2024 15:37 by Kaw-boy 900.
- sf4t7
02 Dec 2024 16:05
Possibly a better way to compare those valves is to position them with the shoulders in line not the ends. Then put the respective needles in them and compare where the needle ends contact the float tangs. That will compare the points where the needle valves shut off the fuel flow.
Scotty
1974 Z1A
Yoshimura 987, 10.25:1
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
- Kaw-boy 900
02 Dec 2024 17:33 - 02 Dec 2024 17:38
S1 250 triple 1973
H1, 500 triple 1975
LTD 1000, 1982
Ninja 1000R 1987
Ninja ZX12R 2006
KZ900 1976. My BB !
Yamaha RD 350 1973
Ducati 1098 2007
S1 250 triple 1973
H1, 500 triple 1975
LTD 1000, 1982
Ninja 1000R 1987
Ninja ZX12R 2006
KZ900 1976. My BB !
Yamaha RD 350 1973
Ducati 1098 2007
Last edit: 02 Dec 2024 17:38 by Kaw-boy 900.
- Kaw-boy 900
02 Dec 2024 18:45 - 02 Dec 2024 18:47
S1 250 triple 1973
H1, 500 triple 1975
LTD 1000, 1982
Ninja 1000R 1987
Ninja ZX12R 2006
KZ900 1976. My BB !
Yamaha RD 350 1973
Ducati 1098 2007
S1 250 triple 1973
H1, 500 triple 1975
LTD 1000, 1982
Ninja 1000R 1987
Ninja ZX12R 2006
KZ900 1976. My BB !
Yamaha RD 350 1973
Ducati 1098 2007
Last edit: 02 Dec 2024 18:47 by Kaw-boy 900.
