KZ305 will not go faster than 50 mph now
  • Matratt3
  • Matratt3's Avatar Topic Author
  • 1987 KZ305-B2
04 Nov 2024 05:24
#905759
Hi All,
Not sure if this belongs in the carb section but here goes:
I recently took the carbs off to replace an o-ring in the swivel fuel T-fitting between the carbs and it fixed the fuel leak. The bike ran well for 4 or 5 rides and had full power. Now it continues to start and idle well but is sluggish after that and will not go more than 45-50 mph.
I took the carbs off and the bottom bowls and cleaned everything and blew out the jets. I did NOT take the top of the carbs off or remove and clean the pilot screw or the jet needle.  I have read that the diaphrams are hard to find and replace so I didn't want any carb cleaner up there or damage the diaphram s in any way. I did puff some compressed air into the diaphram area and the sliders moved easily.
After doing all that and reinstalling....I have the same problem.
I seek advice on what to do next. I am a noob at this stuff, was my first try at a carb cleaning.
I do have an ultrasound bath available. Thanks.
  • ckahleer
  • ckahleer's Avatar
Re: KZ305 will not go faster than 50 mph now
04 Nov 2024 07:09
#905760
See if it runs better on one cylinder or the other. Get a spark plug and ground it to the engine and attach the plug wire to it. Go for a quick full throttle test ride on one cylinder. Do the same for the other cylinder and see if the problem is on only one side.
Another check, with the carbs on a work bench, is pull air through a carb with a shop vac while opening and closing the throttle plate. Do the slides on each carb react the same?
1997 ZL600
94 KE100
82 KZ305
74 TC185
The following user(s) said Thank You: chopper1963
  • Matratt3
  • 1987 KZ305-B2
04 Nov 2024 11:25
#905768
Ok will do. Thank you.
I assume you mean to just rev the throttle after grounding the plug or do you mean an actual ride around?
I dunno how I would do the ride while holding the grounded plug.
  • ckahleer
  • ckahleer's Avatar
04 Nov 2024 14:18
#905770
I mean go for a ride. You want to check things under full throttle under load. Use a piece of wire to strap the plug to engine fins or another ground point.
You could just pull one plug wire, but would risk damaging tke coil, if not attached to a grounded plug.
You are trying to see if one cylinder is pulling much stronger than the other. A 1 minute test ride is enough.
1997 ZL600
94 KE100
82 KZ305
74 TC185
  • Matratt3
  • 1987 KZ305-B2
05 Nov 2024 06:16
#905782
Got it. Will do. Thx
  • Matratt3
  • 1987 KZ305-B2
12 Nov 2024 08:18
#905990
Ok finally got around to doing this.
As I had my spare spark plug and wire for grounding attachment ready I fired up the bike to warm it up first.
Looking and feeling around I see the exhaust pipe and cooling fins next to my right leg gets hot in a couple minutes, the exhaust pipe and fins by my left leg stay cool.
I had tested both plugs for spark earlier and they passed, I swapped the plugs anyway and the left side remains cool and does not warm up.
I wanted to ask if this gives any clues to what might be wrong before going through the carb removal process. Any ideas?
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
12 Nov 2024 10:25
#905992
Worth checking valve clearances and compression but it does seem like a fuelling issue. You could also swop the coils left to right (I know it sparks outside the engine but it may not produce a strong enough spark when in a pressurised cylinder)
  • Matratt3
  • 1987 KZ305-B2
13 Nov 2024 07:02
#906017
Thanks will probably swap those coils before tearing down further to get to the carbs.
  • Matratt3
  • 1987 KZ305-B2
24 Feb 2025 16:24
#909355
Hi Guys,
Finally fixed the problem. It was the carburetor. Gave it a ultrasonic bath and now it runs well.
The first time I put only the jets and lower carb bowl into the ultrasound bath and it did not fix the problem.
I was afraid to get into the diaphragms the first time.
Finally took them off and they were in good shape, and could get to another jet.
Never saw a clogged jet, maybe it was in a passageway.
Sorry it took so long, life got in the way, thanks for all the support and advice. Long ride tomorrow!
Trying to figure out how to edit the title to say (Solved)
