'81 KZ750H2 Fuel Line Sizing?
- SnyperX
30 Oct 2024 10:34
Hey folks!! I continue to work on my '81 KZ750H2. I am going to need to replace the various hoses/lines on the bike for vent and fuel. Does anyone know hose sizing and type used on the '81 KZ750H2? I am ordering my parts via Z1 Enterprises. I tried looking up the parts on Partzilla, but they don't really sate the I.D. and O.D. specs I am looking for. Do I need 1/4", 1/8", 3/16", or 5/16" ID? As always, thanks for reading.
Regards,
SnyperX
1981 KZ750H2 LTD
SnyperX
1981 KZ750H2 LTD
- H1Vindicator
Re: '81 KZ750H2 Fuel Line Sizing?
30 Oct 2024 12:52 - 30 Oct 2024 12:53
Fuel line is typically 5/16 id. 1/4 id vacuum line.
Last edit: 30 Oct 2024 12:53 by H1Vindicator.
The following user(s) said Thank You: SnyperX
30 Oct 2024 15:02 - 30 Oct 2024 15:08
Size 7 X 10.2 mm. Best quality I have found, and a good price to boot.
japan.webike.net/products/24408119.html
Last edit: 30 Oct 2024 15:08 by TexasKZ.
The following user(s) said Thank You: H1Vindicator, Nessism, asphalt900, sf4t7, Wookie58
30 Oct 2024 15:50Suzuki PN 09352-70104-00B. 2000mm = 78" worth of fuel line. Great stuff. It's thin and stretchy. No need for a clamp.Size 7 X 10.2 mm. Best quality I have found, and a good price to boot.
The following user(s) said Thank You: H1Vindicator, asphalt900, sf4t7, Scirocco, Wookie58
30 Oct 2024 16:42
Thanks Texas and Ed - I just ordered some (another piece of the puzzle
- asphalt900
31 Oct 2024 03:57
Ditto Ed's recommendation on the Suzuki fuel hose! One thing to remember when using it though. Because of the thin-wall construction, make you're routing sweeps as smooth as possible. No tight angles or the hose will collapse on itself shutting off petrol flow. Texas, have been considering purchasing some stuff, decal set, from WEBIKE. Have You gotten stuff from them before??
- SnyperX
31 Oct 2024 09:10 - 31 Oct 2024 09:12It states its a water drain hose, not fuel??? Its also $14 shipping to the us......for hose. Yikes.Size 7 X 10.2 mm. Best quality I have found, and a good price to boot.
Regards,
SnyperX
1981 KZ750H2 LTD
SnyperX
1981 KZ750H2 LTD
Last edit: 31 Oct 2024 09:12 by SnyperX.
31 Oct 2024 09:17It states its a water drain hose, not fuel??? Its also $14 shipping to the us......for hose. Yikes.Size 7 X 10.2 mm. Best quality I have found, and a good price to boot.
31 Oct 2024 10:01You can order that PN from any Suzuki dealership.It states its a water drain hose, not fuel??? Its also $14 shipping to the us......for hose. Yikes.Size 7 X 10.2 mm. Best quality I have found, and a good price to boot.
31 Oct 2024 15:35I have bought from Webike several times and have been well pleased with their service and prices.Ditto Ed's recommendation on the Suzuki fuel hose! One thing to remember when using it though. Because of the thin-wall construction, make your routing sweeps as smooth as possible. No tight angles or the hose will collapse on itself shutting off petrol flow. Texas, have been considering purchasing some stuff, decal set, from WEBIKE. Have You gotten stuff from them before??
31 Oct 2024 15:39Yes, it is fuel line in spite of what it says there. Shipping from Japan can be pricey, but most of the time I have found that the total is still less than getting stuff domestically. Definitely check your local dealer and places like Partzilla and Denis Kirk.It states it's a water drain hose, not fuel??? It's also $14 shipping to the us......for hose. Yikes.Size 7 X 10.2 mm. Best quality I have found, and a good price to boot.
- SnyperX
05 Nov 2024 08:27Is that for fuel or vacuum line?Suzuki PN 09352-70104-00B. 2000mm = 78" worth of fuel line. Great stuff. It's thin and stretchy. No need for a clamp.Size 7 X 10.2 mm. Best quality I have found, and a good price to boot.
Regards,
SnyperX
1981 KZ750H2 LTD
SnyperX
1981 KZ750H2 LTD
