1 of four carbs works - sometimes
- JoeJak73
16 Sep 2024 10:32
Fellas, I have a 77 kz1000 ltd with the stock carbs on it. Rebuilt them, put them on the bike and my cylinder 1 isn't working. Put compression tester in, left plug on motor, good spark, 125 lbs compression.
Drained fuel from bowl so I know it's getting in there. Let it run for a few minutes, hit the throttle and then all of a sudden cylinder 1 came to life. If I wait a bit, it'll be like a process reset.
Now I know my brain goes to the warming up expanded or sealed something but there were times I ran this thing for a while, no change. Not sure if the brap on the throttle did it. I didn't do float test because every time I have gas in there. I could take out my pilot and see what's up with that but what else am I missing?
77 kz1000 LTD
Re: 1 of four carbs works - sometimes
16 Sep 2024 12:17
These links may help...
gsarchive.bwringer.com/bikecliff/images/vm_carb_rebuild.pdf
gsarchive.bwringer.com/cbsaunders/gs/pilot_screw_removal.pdf
www.kzrider.com/forum/3-carburetor/61807...-o-ring-kits?start=0
