Date codes Mikuni VM29 smootbore carbs
- willemZ900
- Z1B 4 ever
03 Aug 2024 12:31
Hi All
I Have two Mikuni VM29 smoothbore sets, one is a with Acellerator pump, code on de carb body's is "W/3.
The other one (no Pump) is coded Q2/72 on the body's
Question: is there information/meaning/lists available about these codes or is there a member here who can explain these codes.
Willem
Willem
- Injected
Re: Date codes Mikuni VM29 smootbore carbs
07 Aug 2024 16:33
WG Carbs use to have a forum, don't know if it still exists but he is able to decipher those numbers. I think he has data/lists that he pulls info from.
You may be able to contact him directly as his main web site is still active. Just Google WG Carbs.
1978 KZ650B2 modified project
1981 Z50R Honda tow bike
The following user(s) said Thank You: willemZ900
