screws
screws
21 Jun 2024 13:15
I am trying to spruce up a set of 29 smoothbores for sale, and I want to replace all the old rubber since they have been sitting on a shelf for a really long time. I started disassembly, and ran into my first challenge with the screws that hold the bodies to the bracket. When I realized a screwdriver was not going to do it, I pulled out my trusty impact tool. As soon as I saw it was starting to deform the slots, I stopped. I am now in the middle of a few days of Liquid Wrench therapy, (the screws, not me) which will culminate in a heat treatment and another try.
If somebody has a better trick, I'd be wiling to try it.
Also, does any body know of a source of replacement screws for this? They seem to be yellow cad plated. I hope not to have to destroy any, but I would like to be able to replace one or two if needed.
P.S. I ain't touchin' the jet block.
Re: screws
21 Jun 2024 13:33
Vessel Impacta #3 works great on those screws. I've banged out hundreds of them without damage. Sorry, but I don't know of a good screw replacement source. Please share if you find one.
Re: screws
21 Jun 2024 13:35 - 21 Jun 2024 13:37
Here, but it’s looking like the replacement OEM are not yellow chromate. If you buy them talk to Nessism he might dip them for you. Yellow chromate is just a color dip added after zinc.
Kawasaki 221B0614
Kawasaki 221B0614
Last edit: 21 Jun 2024 13:37 by Mikaw.
Re: screws
21 Jun 2024 15:26
The following user(s) said Thank You: TexasKZ, Mikaw
Re: screws
21 Jun 2024 17:08 - 21 Jun 2024 17:10
Last edit: 21 Jun 2024 17:10 by TexasKZ.
- asphalt900
Re: screws
22 Jun 2024 04:14
Yet another option. Honda 93600-06014-oh. Same head size/taper and JIS #3, 6x14mm. Actually used on a lot of cars too, brake rotors.
Re: screws
23 Jun 2024 18:12
Re: screws
29 Jun 2024 16:22
Welp, patience, more penetrant and some more violence with the impact did the trick wit no more drama. One good whack each got them loose.
Re: screws
29 Jun 2024 16:25
Now my dilemma is, do I replace the one damaged screw with a stainless or zinc screw, knowing it will stick out like a sore thumb, or do I replace all four, omitting seven perfectly useable originals?
My inclination is to do all of them.
Re: screws
29 Jun 2024 16:28
If you are going to this much trouble do them all, keeps it looking uniform
Re: screws
29 Jun 2024 16:50
Hmmmm. Partzilla shows the Honda version as available and it looks a little yellowish. Part number ends in 0A, wonder if 0H superseded it?
www.partzilla.com/product/honda/93600-06...76951227aab05013843c
Re: screws
29 Jun 2024 17:30
The two sets I can find on fleabay do not have the yellow screws and neither set has been cleaned or rebuilt, so I think I should be ok with some shiny stainless or zinc screws there. On set has a plastic cover on the choke lever and plastic floats. Were those later production changes?
