I have a 1981 Kawasaki csr650 and I got a set of mikuni carburetors off of eBay
- Ozzyrocks69#
09 Jun 2024 21:47
I have a 1981 kawasaki car 650 So I got a set of mikuni 24 SS carburetors because the stock carbs had a acceleration pump on them and pieces where missing anyways I cleaned the carbs but just to keep it running aftet i start it and let it warm up it needs about a quarter of the choke to keep it runnining it the pipes and motot get hot real quick also when i.give a bit of throttle it wants to die im running the stock air box it does have a ,4 into 1: exhaust pipe on it the jmain jets in it now are 102.5 also the carbs on it now have the gas/!pilot adjusting on them on the bottom of the carbs ibgot them all right about one and three quarters turns out from lightly seated and the previous owner drilled four holes at the end of the 4 into 1: exhaust pipe so since I swapped out the carbs and the four into one exhaust on it and that some moron drilled 4 dime size holes in the end of the exhaust does anyone think I should jump the main jets to 105 or maybe 107.5 somebody please give me some advise thanks fellow bikers
Re: I have a 1981 Kawasaki csr650 and I got a set of mikuni carburetors off of eBay
21 Jul 2024 19:40
That the choke helps after the bike is warmed up suggests that the mixture is too lean.
It could be clogged pilot circuits or leaks around the carb holders.
When you cleaned the carbs, did you completely disassemble them and soak all the parts in carb cleaner?
The stock jetting should be fine with your setup.
- DOHC
- Those Doe-Hawks really go!
21 Jul 2024 20:20
Here is the answer I gave the last time you posted this question.
kzrider.com/forum/3-carburetor/620487-my...asaki-car-650#900693
'78 Z1-R in blue
, '78 Z1-R in black,
'78 Z1-R in pieces
My dad's '74 Z1
'00 ZRX1100
My dad's '74 Z1
'00 ZRX1100
- Warren3200gt
22 Jul 2024 03:14
If you have fuel screws under the bowls 1 3/4 out is way too rich. Fuel screws should be about 3/4 out.
If you have airscrews on the side they should be about 1 1/2 to 1 3/4 out.
What colour are you plugs?
