kz650f1 carburetor replacement
- adrians
25 May 2024 01:48
Hello Guys,
i have a kz650f1 1981 with some issue to the carbs.So My idea it's to replace it with carbs from kz650b (because find the spare parts is much easier) but i don't if they fit on it.
i'm in contact wit a seller with overhaul carbs for kz650b , but he asked me if my carbs are CV or Vm and i really don't know.
Does anyone can help me?
thanks so much
thanks so much
- zed1015
Re: kz650f1 carburetor replacement
25 May 2024 03:36 - 25 May 2024 04:01
Looking at your previous thread on the same subject last year you have asked for virtually the same advice and you clearly have non pumper VM 24mm slide carbs not CV's.
In your previous thread you even posted a pic of the VMs and stated yourself what they are so i don't know why you now claim you don't know ?
The sellers 'B' model carbs will be the same unless they are the VM22mm versions which you should avoid.
Spares for the sellers B carbs if 24mm are the same as your F1 carbs and are very common.
Again looking at your previous posts and our previous replies i still see no reason why your existing VM's will not work unless there is serious damage to them ( which i doubt ) and maybe the issue you have is likely not carb related but due to other faults or lack of mechanical knowledge.
Last edit: 25 May 2024 04:01 by zed1015.
- 82KZ305Belt
26 May 2024 09:30Looking at your previous thread on the same subject last year you have asked for virtually the same advice and you clearly have non pumper VM 24mm slide carbs not CV's.
Can't answer for the OP, but perhaps poor memory? I couldn't remember something I posted a year ago, lol.
81 KZ650 CSR
77 KZ650B (not in my paws yet)
82 KZ305 CSR
82 KZ305 CSR
