KZ200, no idle warm, hard to start warm.
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
Re: KZ200, no idle warm, hard to start warm.
21 May 2024 12:11
#899467
I did a new test.
Cold engine, open throttle 10bar
Warm engine, open throttle 10,5bar
That equates to 140psi so you can cross low compression off your list of possible causes
  • ckahleer
  • ckahleer's Avatar
21 May 2024 15:46
#899482
Check for overly rich. Is choke plate fully open? Mixiure screw adjustment? Carb bowl fuel level? Correct size pilot jet?
1997 ZL600
94 KE100
82 KZ305
74 TC185
  • Nerdy
  • Nerdy's Avatar
21 May 2024 16:56
#899493
@ Scirocco
ok, I'll check the valve clearence, but wouldn't you here if the clearence is to small (valves not closing) when you pull of the gas handle?
I guess it could also be piston rings, but it doesn't smoke black.
If you had bad piston rings, it would be burning oil and the smoke would be light blue. Black smoke would indicate a very rich fuel mixture and/or a weak spark, leading to incomplete burning of fuel (which would look like a rich mixture).
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
  • LasseT
  • LasseT's Avatar Topic Author
26 May 2024 14:35 - 26 May 2024 14:39
#899767
Ok,
now I have changed spark plug to NGK B7ES with no improvment.
I've added a sound file.
Last edit: 26 May 2024 14:39 by LasseT.
  • LasseT
09 Jun 2024 02:06
#900484
I've got no reply on the sound file.
I've tested the carburettor and manifolds for leaks (start gas), but no signs of leaks.
Is it worth looking for another carburettor?
  • TexasKZ
  • TexasKZ's Avatar
09 Jun 2024 06:56 - 09 Jun 2024 06:59
#900494
The video file will not play for me. I would not replace that carburetor until you are sure it is the problem and it is not fixable.
It could be as simple as a jet came loose and fell into the bowl. Perhaps the float has a small leak and it allowing the fuel level to get too high. As mentioned earlier, perhaps the choke plate has come loose.
I know you said the valve lash and ignition timing were checked before, but I think it would be worth the time and trouble to recheck them , since this is a new problem. If they prove to be within the specified range, then I suppose a thorough look at the carburetor is in order.
Last edit: 09 Jun 2024 06:59 by TexasKZ.
  • TexasKZ
  • TexasKZ's Avatar
09 Jun 2024 07:06
#900495
Perhaps the ignition coil is going bad, and as it gets hot is unable to provide sufficient spark. I would probably put this last on my list of suspects.
