What year LTD got CV carbs?
  • RedPill
  • RedPill's Avatar Topic Author
21 Mar 2024 21:36
#896730
As title asks.
If a 1000ltd has CV carbs, is it a J motor?
Thank you.
  • zed1015
  • zed1015's Avatar
Re: What year LTD got CV carbs?
22 Mar 2024 03:14 - 22 Mar 2024 03:16
#896735
All J type 998cc /1089cc engines ( no provision for kickstart ) had CV carbs as stock ( except injection models ).
All 903cc/1015cc engines ( kickstart equipped) had VM slide carbs as stock ( except the few injection models ).
The KZ CV carbs and VM slides have the same spacing so can be swapped ( with the matching manifolds ) between both types of engine.
Last edit: 22 Mar 2024 03:16 by zed1015.
The following user(s) said Thank You: slayer61, sf4t7, chopper1963, RedPill
  • RedPill
22 Mar 2024 10:20
#896749
Thank you.
I have lines out an a local LTD and a bunch of KZPs.
I might actually pull the trigger on something soon.
My 919 needs a radiator fan, and a cracked exhaust mount welded. Gluten for punishment.
The following user(s) said Thank You: chopper1963
