Vm28 passages holes
- Fox
Vm28 passages holes
28 Feb 2024 09:20
Hello
i actually rebuild a Z1R carb. This one is untested and on the bottom of the carb n4 i can see 1 obstrued hole …
is it nomal ? Why are for those 2 small holes ?
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
1977 kz1000-B1 LTD
- zed1015
Re: Vm28 passages holes
28 Feb 2024 10:09 - 28 Feb 2024 10:13
You need to be more clear and hightlight the holes you mean but the one in the roof of the float chamber ( at 12 oclock in the pic ) is a breather , the blank one at 9 o'clock is the undrilled casting for a fuel screw which is only utilised on the Suzuki GS versions of the 28's which use the same casting and the blank hole at 3 o'clock is the undrilled orifice which would house the accelerator pump nozzle if they were the pumper version ..
Everything that can be seen is correct for the non pumper Kawasaki version of those VM28's .
Last edit: 28 Feb 2024 10:13 by zed1015.
The following user(s) said Thank You: slmjim+Z1BEBE, Fox
- Fox
28 Feb 2024 10:24
Hi,
here in red at 6 hour
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
1977 kz1000-B1 LTD
- zed1015
28 Feb 2024 12:07 - 28 Feb 2024 12:15It is the undrilled breather hole that is only used when the casting is used in the #3 position.Hi,
Yoiu will see that #3 has the breather hole in that position and the other side is blank.
These carb banks are made up of two pairs of common castings which are then drilled and machined to suit their final position.
Last edit: 28 Feb 2024 12:15 by zed1015.
- Fox
28 Feb 2024 12:12
Ok thank you. You mean this hole is just used on carb 3 ?
I want to be sure this is not an error of a previous owner and the fonction of this hole.
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
1977 kz1000-B1 LTD
- zed1015
28 Feb 2024 12:17Yes! That hole is only drilled on number 3 carb.Ok thank you. You mean this hole is just used on carb 3 ?
It is not an error..
The following user(s) said Thank You: Fox
