Kz400b carb balancing
- oldblighty
30 Oct 2023 06:46
Went to balance the carbs on the kz400 and immediately guages reading late valve timing is this normal for these type of carbs .
Re: Kz400b carb balancing
30 Oct 2023 07:55 - 30 Oct 2023 07:56
What is "late valve timing", and why/how is a vacuum gauge providing this information while syncing?
And needless to say, the valve clearances and carb function needs to be otherwise correct before performing a sync. Sync is the last step in the process.
Last edit: 30 Oct 2023 07:56 by Nessism.
- oldblighty
30 Oct 2023 15:11
Hi
its just the red section on these gauges that indicates late valve timing just wondering if anyone has used these gauges and had the same result.
30 Oct 2023 15:27 - 30 Oct 2023 15:29It looks like it is listing multiple possible reasons for a low vacum reading (but not all of them)?What is "late valve timing", and why/how is a vacuum gauge providing this information while syncing?
Last edit: 30 Oct 2023 15:29 by Wookie58.
The following user(s) said Thank You: oldblighty
