82' KZ1000J BS34 #2 carb issue
  • ffltstn
  • ffltstn's Avatar Topic Author
22 Oct 2023 18:54 - 22 Oct 2023 19:15
#890824
Been chasing a rough running, not wanting to idle issue. Carbs rebuilt, coils, wires and plugs replaced, valves checked, new boots, carbs synced at this point.  Bike will not run without the idle adjustment turned all the way up. When I put my hand over the carb intakes 1, 3, and 4 bike will start to die. 2 it will speed up and I think that cylinder is the one backfiring. Bike seems to run better at higher rpm.
'82 KZ1000
'95 Voyager XII
'98 Vulcan 750
Last edit: 22 Oct 2023 19:15 by ffltstn.
  • hardrockminer
  • hardrockminer's Avatar
Re: 82' KZ1000J BS34 #2 carb issue
23 Oct 2023 04:50
#890830
Have you checked compression?
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Moderator
23 Oct 2023 05:21
#890834
Is there an open vacum line on #2 (fuel tap or emission valve/air box)
  • Nessism
  • Nessism's Avatar
23 Oct 2023 07:39
#890839
When you rebuilt the carbs, did you take them fully apart, soak the bodies and all the jets in carb dip, then install all new O-rings?  Did you verify that the pilot passages, both though the jets, and through the carb body up by the pilot screws, and the small orifices in the carb body under the pilot screws, were all open?
  • ffltstn
23 Oct 2023 10:33
#890851
Yes it is a little low in that cylinder but not gone.
'82 KZ1000
'95 Voyager XII
'98 Vulcan 750
  • ffltstn
23 Oct 2023 10:34
#890852
I did dip them and thought I had them clean. Does it sound like something that would happen with a dirty idle circuit?
'82 KZ1000
'95 Voyager XII
'98 Vulcan 750
