z1r different float bowl numbers
- david richard
03 Oct 2023 23:10
hi i have a spare set of z1r 28 mm carbs and what do the float bowl numbers mean they are 35 and 45 yet are the same thanks
Re: z1r different float bowl numbers
04 Oct 2023 06:19
What numbers are you referring to? Can you post a photo?
What I do know is that VM carbs like yours will have two pairs of float bowls, one with the drain outlet pointing right, and the others pointing left.
The following user(s) said Thank You: slayer61, david richard
04 Oct 2023 08:03
I have seen numbers cast inside and on the bottom of the bolt on VM carbs. If I remember correctly like #2’s and 3’s. I don’t recall anything 35 or 45. I could not find and correlation to the numbers I have seen number 2’s on rights and number 2’s on lefts. As mentioned photos will help
The following user(s) said Thank You: david richard
- david richard
04 Oct 2023 09:43
yes these are the carbs sorry the one upside down is 35 the other is 45 thanks
- david richard
04 Oct 2023 09:52
yep should say they are stamped on all of the bowls thanks
- z1kzonly
04 Oct 2023 10:20 - 04 Oct 2023 10:21What numbers are you referring to? Can you post a photo?
"Sorry to but in here", I don't check in often, always have something going on.
Hi Ed, I'm looking for just 1 OEM 28 mm, 1973 bowl 17mm drain cap for #1 carb the (dyno charge side)
Yes that make sense 2 sides each part # Just like exhaust collars have 2 each.
Marty in Buffalo
Last edit: 04 Oct 2023 10:21 by z1kzonly.
04 Oct 2023 10:36
I just checked a set of VM28 pumpers I have here, and they have very poorly stamped "40" on them. Maybe they are some sort of batch number used internally at the Mikuni factory?
- david richard
04 Oct 2023 10:48
hi yes thanks it just has to something like that cheers
