Leaking O-Ring on both carbs KZ440 C1
  • scardracs
  • scardracs's Avatar Topic Author
20 Aug 2023 07:09
#888518
Hi everyone.
As title said, I’ve a KZ440 model C1 and both carbs are leaking gasoline. I need to change both orings but I haven’t found anyone who can have them. Could you help me please?
  • Nessism
  • Nessism's Avatar
Re: Leaking O-Ring on both carbs KZ440 C1
20 Aug 2023 07:18
#888519
I sell O-ring kits.  What O-rings are leaking?  And where on the planet are you located?
The following user(s) said Thank You: scardracs
  • scardracs
20 Aug 2023 07:59
#888520
Hi! I’m located in Italy. The leaking orings are the biggest ones on both carbs (these on the perimeters). Sorry for non technical terms but I’m really new here
  • Nessism
  • Nessism's Avatar
20 Aug 2023 10:26
#888524
The float bowl O-rings?  If so, they are 67mm ID x 1.0mm thick.  Use superglue to hold them in the groove.
Since you are rebuilding the carbs, I strongly recommend a full rebuild.  Ungang the carbs, soak the carb bodies and jets in a carb cleaner solvent, then reassemble with all new O-rings.
If you can't fine the needed parts in your local market, email me at nessism AT sbcgloabal DOT net
