idle on1973 h1
  • hydrolazer
  • hydrolazer's Avatar Topic Author
idle on1973 h1
02 Aug 2023 04:21
#887800
my bike idles at 500 rpm...is there an adjustment that does all 3 carbs at the same time so i dont get them out of sync?,,,tia
\'79 kaw 1000 ltd
  • TexasKZ
  • TexasKZ's Avatar
Re: idle on1973 h1
02 Aug 2023 07:42 - 02 Aug 2023 07:53
#887817
Nope. Each carb has an idle speed adjustment screw that should be adjusted after setting the low speed mixture. Look at the Tuning section, about 3/4 of the way through the document.Notice that synchronizing is done first.
3cyl.com/mraxl/manuals/carbtune/carbtune.pdf
Last edit: 02 Aug 2023 07:53 by TexasKZ.
  • hydrolazer
Re: idle on1973 h1
02 Aug 2023 08:41
#887821
ok thanks
\'79 kaw 1000 ltd
