Oil in carbs?
  • Beaner242
  • Beaner242's Avatar Topic Author
Oil in carbs?
27 Jul 2023 16:40
#887660
Just pulled my filters off to clean them. Each carb had a small amount of oil on the lip and in the filter? Never seen this before. It got ran pretty hard last weekend, would that have something to do with it?  Any ideas?  Thanks
1982 KZ1000K LTD Chopper
  • TexasKZ
  • TexasKZ's Avatar
Re: Oil in carbs?
27 Jul 2023 20:01
#887667
Could the filters have been over oiled when they were last installed?
  • Warren3200gt
  • Warren3200gt's Avatar
Re: Oil in carbs?
27 Jul 2023 20:54
#887668
It's probably evaporated fuel if you used ethanol laced fuel. The residue from evaporated ethanol fuel is brown. When fully evaporated its looks like a varnish, this is what clogs carbs if bikes are left for a while without draining the carbs.
There's no engine fluids that get to carbs other than fuel.
  • Beaner242
Re: Oil in carbs?
28 Jul 2023 04:46
#887676
Yes, but not that much. And this was like engine oil.
Thanks warren.  That could be it. Just seemed excessive I got fuel at 3 different stations last weekend though.
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Moderator
Re: Oil in carbs?
28 Jul 2023 04:48
#887677
Is it fair to assume that you are running pods and the crankcase is venting to atmosphere ?
  • Beaner242
Re: Oil in carbs?
28 Jul 2023 05:52
#887678
Into filter
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Moderator
Re: Oil in carbs?
28 Jul 2023 06:09
#887679
When you "into filter" is this a separate unit or the air filter (normally if the breather is connected to the air filter oil in the intake is a sign of excessive crankcase pressure)
  • Beaner242
Re: Oil in carbs?
28 Jul 2023 06:19
#887680
Sorry yes I have pods and a separate filter/breather on the case.
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Moderator
Re: Oil in carbs?
28 Jul 2023 06:27
#887681
There aren't too many options for oil to get into the intake under these circumstances, a leaking valve seal would normally result in the oil being drawn in and burnt. it would be very unusual for oil to find it's way out to the carb intakes ???
  • Beaner242
Re: Oil in carbs?
28 Jul 2023 06:34
#887682
Thanks. That’s what I thought. Like Warren said. Prob a fuel issue. Just never noticed it before
  • F64
  • F64's Avatar
  • 81-KZ440D2
Re: Oil in carbs?
28 Jul 2023 09:08 - 28 Jul 2023 14:50
#887686
You may be dealing with intake reversion and leaky valve seals.
www.motortrend.com/how-to/ctrp-1008-intake-reversion/
Your exhaust pipe may be sending a strong positive pressure wave back to the cylinder during overlap at certain rpm's.
This is due to pipe length and internal size changes of the primary pipe.
Collector design and placement plays a role as well.
Two stroke tuners have been use this tuning method to their advantage.
You can use it as well but you need to do the math.
The cloud of fuel above the intake trumpets shows reversion in action on the Renault F1 engine.
81-KZ440-D2.
LIC, NY
Last edit: 28 Jul 2023 14:50 by F64.
  • Nessism
  • Nessism's Avatar
Re: Oil in carbs?
29 Jul 2023 06:03
#887698
Are the valves adjusted properly?  If the intake valves are hanging open, there may be a bit more blow back.
