What’s this spring lever under the carbs?
- treyhova
19 Jul 2023 00:19
Anybody know what this is? And what it does? Spring lever upside down under the carbs. Pushes up but springs back down.
Attachment not found
- KZQ
- Administrator
Re: What’s this spring lever under the carbs?
19 Jul 2023 06:16Did you use the "Back" button while composing your post? If you did that's why the software lost your image. Please try again, this time without the back button.Anybody know what this is? And what it does? Spring lever upside down under the carbs. Pushes up but springs back down.Attachment not found
Please let me know if I'm mistaken.
Bill/KZQ
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
19 Jul 2023 06:38
Difficult without a picture but sounds like an accelerator pump ?
- treyhova
19 Jul 2023 10:56
Looks like you are having issues attaching your pics, follow the below process
Click "attachments" - click "add file" - select your pic - wait for the green text to appear - click "insert all" then submit and you should be good to go
- treyhova
19 Jul 2023 11:28
Accelerator pump. Twisting the throttle should move the lever. To see if it is working, remove a filter and peek inside as you twist the throttle. You should see a small squirt of fuel.
The following user(s) said Thank You: treyhova
19 Jul 2023 14:22 - 20 Jul 2023 04:58
Just in case. You should see a small squirt of fuel... in each carburetor. see the manual for other details.
Last edit: 20 Jul 2023 04:58 by martin_csr.
- gd4now
- Denco where did you go?
19 Jul 2023 22:16 - 20 Jul 2023 10:17
From the pic posted it appears that this set of carbs has both a pump and a sensor. As I understand it one of the things the sensor does is only allow fuel out of the pump if the engine is running (providing vacuum)
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
Last edit: 20 Jul 2023 10:17 by gd4now.
The following user(s) said Thank You: Nessism, TexasKZ, treyhova
- treyhova
20 Jul 2023 13:44
Thanks for all the great info fellas! I just picked up a 79 KZ650... B3 I think... it's black with the green and yellow striping. Pretty good condition overall but the engine is sounding a bit off, and I suspect it's running lean overall - so was wondering if that lever connected to the carbs had anything to do with it.
- gd4now
21 Jul 2023 09:36
A 650 with accel pump with sensor, I had read/heard that some of them did have both but had not seen one or worked on one. The pic you posted showed pod filters not air box, so I would think some jetting changes from stock would be required. Any idea what jets are in it now?
1977 KZ650 B1
- treyhova
21 Jul 2023 09:58
No idea what jets are in currently. Any suggestions?
