Carb rebuilding
  • mvent
  • mvent's Avatar Topic Author
Carb rebuilding
12 Jul 2023 14:15
#887165
Want to have carbs totally gone through, new o-rings, plating, vapor blast ext etc. looking for recommendations from first hand experience. Carbs are off Z1B.
76 KZ900
76 XLCH
78 KZ1000
04 FLSTFI 120 ci
  • MotorcycleMechanic86
  • MotorcycleMechanic86's Avatar
Re: Carb rebuilding
12 Jul 2023 16:10
#887170
I’ve had good success with wired George carburetors. He’s in Texas. It’s been a while since I’ve used him I do all my own carb work now.
  • Nessism
  • Nessism's Avatar
Re: Carb rebuilding
12 Jul 2023 16:24
#887172
No disrespect to MotorcycleMechanic86, but I have rebuilt TWO sets of "George" carbs, after the owners couldn't get the bike to run for crap.  On inspection, they were FULL of glass bead grit.  Also, he blasted all the zinc plating off the steel parts, and then sprays them with some clear coat crap, instead of replating.  And many of the steel parts were rusting.
Re: Carb rebuilding
12 Jul 2023 16:50
#887174
It’s been a good 10 years plus since I’ve used him so maybe his quality has went down hill.
  • Nessism
  • Nessism's Avatar
Re: Carb rebuilding
12 Jul 2023 17:06 - 12 Jul 2023 17:53
#887175
Could be "George" has some "helpers" that are butchering things.
Oh, and forgot to mention, but one of the sets I rebuilt was attacked with a sanding drum in the throttle slider bores.  I was aghast!
And he used RTV to try to seal the crappy fuel tees...
Last edit: 12 Jul 2023 17:53 by Nessism.
Re: Carb rebuilding
12 Jul 2023 17:17
#887176
Wow that’s crazy. Honestly crap like that is why I started doing all my own work. Then it grew to me doing for a friend and so on. Now I do it for a living lol
  • sf4t7
  • sf4t7's Avatar
Re: Carb rebuilding
12 Jul 2023 19:04
#887178
Yikes !
Scotty
Scotty
1974 Z1A
Yoshimura 987, 10.25:1
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
  • mvent
Re: Carb rebuilding
14 Jul 2023 14:47
#887215
Nessism is this something you do for others or just for yourself?
76 KZ900
76 XLCH
78 KZ1000
04 FLSTFI 120 ci
  • Nessism
  • Nessism's Avatar
Re: Carb rebuilding
14 Jul 2023 15:34 - 14 Jul 2023 15:34
#887217
I do lots of rebuilds for others.  Check this thread for photos of my work.  This thread has my email address inside too.
www.kzrider.com/forum/forum-index/23-for...4-set-from-1000-1100
A full-blown rebuild, with bead blasting and steel part plating, obviously costs more, compared to a functional rebuild.  email if you want to discuss...
Last edit: 14 Jul 2023 15:34 by Nessism.
  • Cra-z1
  • Cra-z1's Avatar
Re: Carb rebuilding
14 Jul 2023 16:00 - 14 Jul 2023 16:00
#887218
It's always best to learn how to do it yourself. I recently rebuilt a set of CBX carbs that someone(a motorcycle mechanic instructor) rebuilt for a friend. I would not bead blast the carb body. Ultrasonic clean yes but bead blast no. take your time get a manual think about how they operate and you will be good. Really, silicone on the tee's.
Last edit: 14 Jul 2023 16:00 by Cra-z1.
  • Nessism
  • Nessism's Avatar
Re: Carb rebuilding
14 Jul 2023 17:32 - 14 Jul 2023 17:35
#887220
I bead blast all the time.  You got a problem with these, Cra-z1?  And are you saying you support silicone on the Tees?
Last edit: 14 Jul 2023 17:35 by Nessism.
  • krazee1
  • krazee1's Avatar
Re: Carb rebuilding
14 Jul 2023 19:33
#887222
I have a set of carbs that Nessism rebuilt on a 1980 750E 4cyl. I bought them a few years ago on EBay, before I was a member of this Fine Forum. Top-Notch work, still running beautifully!
I Think,  Cra-z1 was being sarcastic about the silicone?
Mike
1974 Z1
1978 KZ1000 LTD
1976 KZ900B pile O parts
1980 KZ750E
