81 KZ440 LTD carb jets
- Yoshi
17 Jun 2023 11:25
Have an 81 KZ440 LTD, bought it with pods and free flowing exhaust. It's running very lean and I can't go full throttle without major lag and then starts overheating. What size jets do I need in the carbs to eliminate this problem? 70 main and 90 secondary is what it has now
- Nebr_Rex
Re: 81 KZ440 LTD carb jets
18 Jun 2023 15:53
You will need more than just jets.
Get the DynoJet jet kit for the KZ750H which is a 4 cylinder.
The carbs are almost identical to each other between the two bikes
That is the best anyone can do short of having access to the Sudco warehouse.
As for the use of slide carbs anything larger than a 28mm is overkill.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
