Z650 VM24SS Snapped Pilot Screw
- SeanBP
29 May 2023 13:18
Hopefully someone can give me some advice to save me from my own stupidity !
I've got 3 sets of carbs in total, one on the bike and two spares. It's a Z650B1, with VM24SS carbs - no two sets quite the same !
I'm working on refurbishing the spare sets to make them both usable, and met a problem with one of them. It's the transitional type, with air screws at the back and pilot screws under the front of the float bowls.
The problem is that two of the pilot screws are snapped off about 5mm below the tip. I'm pretty sure it's my fault from doing them up a little too tight. What I am wondering is, has anyone found a way to get the broken off bit out of the carburettor safely ?
The carbs are clean, so I'm thinking a squirt of carb cleaner just to dissolve any tiny amount of varnish that might be up there, then stick them upright in the ultrasonic cleaner in the hope that the vibration and warmth it created might work the needle tip loose, possibly with some gentle pressure from the flat of a screwdriver blade. But is there a better way, and anything I should be aware of to avoid making the problem worse than it already is ?
Thanks !
Thanks !
- Warren3200gt
Re: Z650 VM24SS Snapped Pilot Screw
29 May 2023 15:37 - 29 May 2023 15:39
Bad position to be in. I would definately not try to push the tip out using anything to might deform the very fine tip of the needle making it even harder to remove without affecting either the throat hole diameter or the body taper.
I have had some success removing tips by firstly soaking them in carb cleaner for a day or so.
Then using a can of aerosol carb cleaner with some small diameter tubing on it. Remove the carb slide and insert the tubing down the slide bore. Hold the open end of the tube over the needle tip tight against the carb bore and giving it a few good blasts of aerosol carb cleaner.
Hopefully the soaking and pressure from the aerosol is enough to shift the needle tip.
Sometimes works sometimes doesn't!
Last edit: 29 May 2023 15:39 by Warren3200gt.
29 May 2023 16:06
The following user(s) said Thank You: Nessism, Wookie58
