Left the petcock open overnight
- 1981KZ550
25 May 2023 10:27
I have an '81 KZ550A, and could not get the original vacuum petcock to stop leaking, so I replaced it with a manual petcock. Its been running fairly well, but the other day, I rode and then accidentally left the petcock in the open position overnight. I drained the float bowls, and fired it up. Seemed to run fine, but after a few minutes it sputtered and conked out. I changed the oil and plugs, did not see any metal shavings or signs of fuel in the oil. I can get it to idle fine, but when I down shift it sputters and dies. Help! Thanks,
- ckahleer
Re: Left the petcock open overnight
25 May 2023 16:17 - 25 May 2023 20:23
Did the carbs overflow? Was there gas in the cylinders, airbox, or oil? Could it just be coincidence that the problem started after leaving the petcock on overnight?
I many times have forgoten to turn my petcock off without it causing an issue. 99% of the time the float needles keep the carbs from overflowing.
1997 ZL600
94 KE100
82 KZ305
74 TC185
94 KE100
82 KZ305
74 TC185
Last edit: 25 May 2023 20:23 by ckahleer.
- 1981KZ550
20 Jun 2023 05:13
Thanks. No carbs didn't overflow. I think now I realize its more of a fuel flow issue. When I added the fuel filter I had to extend the fuel line and it has to run "uphill" a bit from the petcock. I plan to shorten the fuel line and create a more direct "downhill" flow from the petcock to the carbs. We'll see....
